Posted November 4, 200421 yr I've noticed for some time now that it's complicated to figure out the power for a three sub setup. If you have three 4 ohm DVC subs wired together in series (in think thats right) you get a 2.67 overall ohmage. Now if you have a KX600.1 for 600@2ohms, or perhaps a DX700 for 700@2ohms; how would you figure out how much power the amp would put out at 2.67 ohms? Looking into possibly 3-10" compvrs with that setup.Also, I was looking into a two sub setup with the Brahma 10. I'm thinking maybe a bpx1100.1 to power that setup. This one is more expensive, but alot louder and more SQ. After all that 29mm one way linear xmax sure isnt dissapointing!Both setups would be in a ported box, and the three sub ported box setup would prove to be quite challanging.Thanks for your help.
November 4, 200420 yr I used to own a DX700 and 3 10" compvr's, sealed though. Personally, I'd go for the brahma/jbl any time. They sound better and can get louder with right enclosure and power. You can't really figure out power output exactly without benching it but a solid guess would be since the dx700 does 350 at 4 ohms and around 700-800 at 2 ohms that it would do around 600 or so watts (just mathematically since halving the impedence doubles the power).
November 5, 200420 yr Ok, what you are doing is called series-parallel wiring. You series the subs to 8 ohms each, then parallel the 3 subs to achieve your 2.67 ohm load. I would agree with bigger, it is tough to tell how much power the amp is putting out. First, the coils are usually not exactly 4 ohms, they are a tad off. Then you have the in box impendance rise to worry about. But probably on a DX700 you would see 600-650 at 2.67 depending on what the bench test is for 2 ohms.
November 5, 200420 yr Author thanks for the replies, I think I'll avoid the three sub setup for now and stick to the brahma jbl setup. How nessecary would a subsonic filter be for the brahma jbl setup, I'd hate to blow $700 worth of subs because they went too low. I think FMod makes a 30 hz highpass filter that rolls off at 12db/octave. As far as I know, that bpx1100.1 doesnt have a subsonic filter.
November 5, 200420 yr The need for a sunsonic filter depends on where your box is tuned to and what music you listen to. The safe bet is have a subsonic filter set around 5 hz below box tuning. For a dialy driver the box is usually tuned to around 35 hz and the subsonic would be set at 30.
