Posted June 19, 200818 yr I am getting very mixed opinions about this. I have 2 12 inch ssd's going in a 04 escalade running off of a saz 1500d. What should I make a sealed or a ported enclosure. give me the reason why don't just pick one. What is the biggest difference between the two. It is my first real setup, so I don't know. The SSD's can be in either enclosure.
June 19, 200818 yr I am getting very mixed opinions about this. I have 2 12 inch ssd's going in a 04 escalade running off of a saz 1500d. What should I make a sealed or a ported enclosure. give me the reason why don't just pick one. What is the biggest difference between the two. It is my first real setup, so I don't know. The SSD's can be in either enclosure.If you want loud, go ported. Musical accuracy, go sealed. I will add that 2 12's will still get loud even if sealed. But the ported will be louder.
June 19, 200818 yr Author I am getting very mixed opinions about this. I have 2 12 inch ssd's going in a 04 escalade running off of a saz 1500d. What should I make a sealed or a ported enclosure. give me the reason why don't just pick one. What is the biggest difference between the two. It is my first real setup, so I don't know. The SSD's can be in either enclosure.If you want loud, go ported. Musical accuracy, go sealed. I will add that 2 12's will still get loud even if sealed. But the ported will be louder.Thank you for the input anyone else have some info?
June 19, 200818 yr just what scizzle saidand it all depends on what you are trying to go for, what music do you listen to?
June 20, 200818 yr Author jazz, rap, rock, christian, hip hop, everything except for country and screaming death metal
June 21, 200818 yr I would go with a low tuned ported enclosure so you don't have peaky output.....I'd do that too but just remember that what Dave Edwards is suggesting is: A REALLY BIG BOX
