Posted June 22, 200818 yr I'm trying to make a list of things I need to get and/or do. I'm going to do the big 3, upgrade my battery,and already got a HU. Okay I have a 15" fi BL, if anyone could point me to some spec of a box with good SPL that would be very helpful. I've aslo got a RF 1500-1bd so would I need 1 or 2 batteries for it all.Could I use one battery to run my car and the system with no dimming of my lights? My alternator is stock, but I don't know much about them so how many amps would be good? I'm putting it all in a 99' Jeep Grand Cherokee. Thanks in advance.
June 22, 200818 yr You can indeed use one battery for your system and one for your car. You'll need an isolator to do so. One midsized battery for that amp should be all you need.As far as box for the BL goes, look here : http://www.soundsolutionsaudio.com/forum/i...?showtopic=7154
June 22, 200818 yr Author You can indeed use one battery for your system and one for your car. You'll need an isolator to do so. One midsized battery for that amp should be all you need.As far as box for the BL goes, look here : http://www.soundsolutionsaudio.com/forum/i...?showtopic=7154Alright well would this batt. be powerful enough?http://www.kinetikaudio.com/hc1400.asp
June 23, 200817 yr ^ id bump up to an 1800, im sure either would work though....go here if you have any other questions about how many batts youll need....http://www.kinetikaudio.com/calc.asp
