Posted June 24, 200818 yr So friends down under can now take advantage of decent pricing on Mach 5 products from Affordable Drivers. They have received their stock and are now shipping:http://www.affordabledrivers.com.auBest,Mark
June 24, 200818 yr Already paid for 2 IXl.18's, just waiting for them to show up on my doorstep Edited June 24, 200818 yr by RAD
July 20, 200817 yr Any idea if I can get the mli65 from them. Seems that they do not have any in stock.
August 10, 200817 yr perhaps i'll convince my sister's bf to get into car audio and buy some Mach5 subs in OZ
October 12, 200817 yr Hmmmm IXL 10 is on its way to me...... Yay for me. Boo for not having enough amp to buy 2.......
October 19, 200817 yr Hi Crosspug!Hopefully you've had a chance to checkout the driver?Time to build that box!Sam
October 19, 200817 yr Hi Crosspug!Hopefully you've had a chance to checkout the driver?Time to build that box!SamHi Sam,Ha, that thing is freakin' heavy (twice the weight of my current 12inch). Very solid build, and just plain sexy!I'm in the process of making a 0.85cube box which I'll pad down to 0.7cube with sand bags and run sealed until I get my external port built then add it on. It'll be ugly but hopefully it'll sound great. Thanks for the great service btw.Jono
November 14, 200817 yr Just got the newsletter (which i got a mention in!)Too bad their arrival is on the 28th, theres a club demo on the 27th i was hoping to have 4 IXL's rocking for.
November 15, 200817 yr 4 18's sealed ? :bigclap:Technically sealed, but its kind of a Quasi 4th order bandpass. Hits hard and sounds good doing it, its designed for 18 cubes before drivers and the manifold; perfect for 4 IXL's, so when theyre in, it should be something to experience ...
November 18, 200817 yr 4 18's sealed ? :bigclap:Technically sealed, but its kind of a Quasi 4th order bandpass. Hits hard and sounds good doing it, its designed for 18 cubes before drivers and the manifold; perfect for 4 IXL's, so when theyre in, it should be something to experience ...Make sure you post up some numbers with this setup. I'd love to try something similar What was the highest your other setup metered ?
November 20, 200817 yr There's a comp coming up on the 30th, i'll let you know how it goes! Hopefully still in the 150's, too bad the next shipment of IXL's wont come in time for me to have 4 of them running Highest was 151.5 @ 51hz with the ported setup; not enough port area held it back.
January 29, 200917 yr Just a quick note to say thanks to Sam for the great service once again down here in Oz. Oh and I suppose Thanks Mark for the nice little woofer you call IXL10. JonoPS Rad wheres the updates??......
February 5, 200917 yr crosspug: no updates yet, just waiting on sub #4 to land at my door, get the auto fixed and im off pounding again.Hopefully with #4 in, it will make the enclosure volume more optimal to the recommended 4.5cubes. That, and with more cone area, and loading the amp lower, im hoping it'll do 150+ on music all day long.
