June 27, 200818 yr One of my friends has it and when I asked him about it he replied with:I like it, haven't really used it much though. I bought it to find out the Fs of the subs so I could build my comp enclosure so I don't really use it anymore. I check the Fs on occasion, but thats about it. Once I start building some more I'll use it more. I was talking to some people at a drags 3X show and they had a program that was pretty close to it, they said PartsExpress. com had actually ripped off that program from them. Apparently Parts Express only used a small portion of it and it only gives you 1/4 of the info you really need to build the right enclosures. Partsexpress charges $99 for this program and the real one was like $250. You can check out the real one at www. woofertester. com
June 27, 200818 yr I have it. I just picked up a 15ft USB extension cable so I don't have to sit an 18" sub on my desk. I also have to work on finding the Vas which is a little more difficult than the other parameters.-Robert
June 27, 200818 yr So it does work then? Fantastic idea for any professional box builders to get one, seeing how it's only $99.
June 27, 200818 yr Admin I was thinking about getting one. Will look forward to see what Robert says.
June 28, 200818 yr I was planning to order one if for no other reason than to play with it. Vas is fairly to simple to test with something like that IIRC. Simply a matter of loading it into a known enclosure and seeing how the parameters shift from the free-air parameters.
June 28, 200818 yr The WT3 is a fine option. The real advantage to it is the quickness with which you can take Thiele/Small measurements.http://audiojunkies.com/blog/1016/wt3-woof...ew-dayton-audio
June 29, 200818 yr I was planning to order one if for no other reason than to play with it. Vas is fairly to simple to test with something like that IIRC. Simply a matter of loading it into a known enclosure and seeing how the parameters shift from the free-air parameters. But I don't have enclosures for every driver ranging from 3" to 18". I've been trying to find information on using the added mass method. I think it would be easier but I need a known mass as well as a method of attaching it to the cone. I don't want to leave a mark on the cone either.I just tested my TC Sounds/SVS Ultra/Audiomobile Mass driver. Interesting results:Re 3.547 ohmsFs 25.57 hzQts 1.145 (much higher than expected)Qes 1.383 (much higher than expected)Qms 6.656Le 1.092Mms (missing)Vas (missing)Once I run my Vas test, the Mms should be filled in as well.Also, the parameters change depending on the orientation of the driver. The specs above were taken with the driver sitting cone up on the floor. Here they are with the driver horizontal on the floor.Re 3.428 ohmsFs 26.24 hzQts 1.152Qes 1.343Qms 8.109Le 1.092I need to find the preferred driver orientation and stick to it.All in all, I'm happy with the tool. As with most precision measuring devices, there is a learning curve and I am at the bottom of it. But with the number of drivers that I don't have info for and the recones that I have been doing, it will at least give me an appoximation of the T/S parameters.-Robert
June 29, 200818 yr Horizontal should be more consistent because the weight of the cone won't cause the suspension to sag. For the delta-mass method, once you have a known wieght to work with, stick it to the cone with a control piece of Blu-Tac (i.e. weigh the Blu-Tac and keep the same piece for future use).
