Posted July 3, 200817 yr I have a 15 inch Fi SSD with a bout 800 watts going to it. I want to get some front 6.5 components that will be able to keep up with it. I have a kicker 150.2 amp so that should be able to do about 100 watts x 2. Budget around 100 dollars but I will go higher or lower if its worth it.
July 3, 200817 yr Try to find some more money. 100 doesn't go far for good components. Otherwise I'd say just go to your local shops and listen to some there so that you get what you want.Pioneer's budget line isn't too bad. I think Kicker makes a line around there that isn't bad either (though I personally don't care for Kicker). Might be able to find some JL Audio VR's for that, they're good (and use the silk dome too, I believe).
July 4, 200817 yr Author How much should I raise my budget? I am only getting one pair I want to buy some raamat as well so I really dont want to raise my budget. What about PGs 6.5? Edited July 4, 200817 yr by darkhunter139
July 6, 200817 yr Author What are hte cheapest rainbows? Is there any place I can get them used or something? Also any input on PG 6.5s?
July 7, 200817 yr It all depends on your definition of "keep up". For mine you'd have to spend more on your front stage than on your sub, amp and box. Obviously that isn't the case in your definition, but it would be easier to understand if you defined it.
July 7, 200817 yr Author It all depends on your definition of "keep up". For mine you'd have to spend more on your front stage than on your sub, amp and box. Obviously that isn't the case in your definition, but it would be easier to understand if you defined it.I just want them to get loud, have good SQ and sound nice with my sub
July 7, 200817 yr Depends on the "really nice" part. Personally I wouldn't throw any less than 250 on the comps
