Posted July 9, 200818 yr hi! i need you good opinions on this amps:KICKER 750.1- - $410.66# Class D# Amplifier Type 1 Channel# Mono subwoofer amplifier# 375 watts RMS x 1 at 4 ohms# 750 watts x 1 at 2 ohmsALPINE-MRP-M1000 - $451.72# Mono (single channel) V-Power BASS amplifier# Class D# RMS Power (at 14.4V THD+N, 20Hz-20kHz)# Per channel into 4 Ohms: (@ 14.4V +-1%THD+N, 20Hz - 200Hz) 600W x 1# Per channel into 2 Ohms: (@ 14.4V +-1%THD+N, 20Hz - 200Hz) 1000W x 1i'm from europe...the price are the cheapest i can find.. in europe..thanks
July 9, 200818 yr Perhaps neither then. Ford was dead nuts on, either amp is fine but neither are optimal for your setup although if you have to choose the Kicker is a lot closer.
July 9, 200818 yr Author my sub is dual 4ohm... paralel wired up gives me 2ohm load.. so...looking to power..the alpine is just perfet..but..the kicker have 900 or more real watts, alpine 1000 or more too.. but i would like to hear your opinions about them!sorry about my messed up english..bue i'm portuguese...
