Posted July 9, 200817 yr I'm in the process of buying a 15" BL within the next two weeks. i was going to pay someone to build me a box, but its going to cost +$200 and take well over 3 weeks for him to build it.so i decided to do some some research (and save some $$$$) and found two enclosure plans that fit the 15"what one should i build?the first designThis will work. Around 3.85 ft^3 tuned to 33 Hz. You could double the front baffle making the box 19.25" deep and get rid of the two small braces.or this oneNet volume: 3.5cuftTuning: 33HzPort Area: 52.5(15"Hx3.5"W)Dimensions:16.5H"X24D"x26.5W"*design stolen from ROE.Another question, Its a fully loaded 15" Bl powered by a rockford fosgate T1500-1BD the amp is rated at 1000W x 1 @ 2-Ohms RMS1500W x 1 @ 1-Ohm RMSis it safe to wire the subwoofer at 1ohm for daily play?i know they can take a good amount of power, but how much is safe for continuous daily play? sorry for the noob questions. Edited July 9, 200817 yr by kayone707
