Posted July 22, 200818 yr Is the atlas 12 able to be used in an IB set up for car audio? I can't find any of the old specs.
July 22, 200818 yr IIRC the atlas have the variable Qts. setting. I think it is possible because one setting had a high-ish Qts, but I don't remember any other key partameters or the speaker.
July 22, 200818 yr High Qts setting should work fine with it...need to get it up around .67 for it to work in IB properly..I'm not totally sure the arrangement on the sub off the top of my head, let me do some research and i'll get back to you..Thanks!-Nick
July 26, 200818 yr Author High Qts setting should work fine with it...need to get it up around .67 for it to work in IB properly..I'm not totally sure the arrangement on the sub off the top of my head, let me do some research and i'll get back to you..Thanks!-Nickthanks i had the info at one time lol lost it in a reformat
July 26, 200818 yr Description of wiring options for the Atlas 12 and 15.http://web.archive.org/web/20050307070748/...dard+wiring.htm
July 26, 200818 yr Author Description of wiring options for the Atlas 12 and 15.http://web.archive.org/web/20050307070748/...dard+wiring.htmthankies!
