July 23, 200818 yr Author No one knows the freq range on the C1's? Can't find anything in the instruction manual, just that the passive crosses them at 5K, and the range of the entire 61-2 set (50-22KHz)
July 23, 200818 yr You gotta think that whoever designed that passive for those drivers MUST know something about the optimal bandwidth performance for them. What is with the obsession of forcing tweets down so low these days?? Active is cool and all, but jeepers.
July 23, 200818 yr Author You gotta think that whoever designed that passive for those drivers MUST know something about the optimal bandwidth performance for them. What is with the obsession of forcing tweets down so low these days?? Active is cool and all, but jeepers. Ok, ill stick with the 5K like the passives provide then. =\
July 25, 200818 yr for better answers check out the official hybrid audio forum, www.buwaldahybrids.com he has a lot of good stuff on there, and most of the team memers also post on there. FYI Scott did a ton of testing with those, and I believe he said the tweet could play down to 3khz if you really wanted, but for best performance 5 khz was used, 4.5khz was very close as I believe he almost went with that when designing the passives. See, he posted things he was doing with the clarus series on his own forum before they came out.
July 26, 200818 yr Author Scott got back to me on this, it can play lower but could have adverse affects on other things. 5KHz it is Edited July 26, 200818 yr by sick6ness
August 5, 200818 yr Sorry for the lack of public reply. My SSA clone was on vacation for the last two weeks. The C1 can easily play to 3,000 Hz. I just don't recommend it for this or any other tweeter.Scott
