Posted July 22, 200817 yr I know the rms rating on the havocs is 1250 but how much can they really take? would an SAZ-3000D be too much?
July 22, 200817 yr lol you dont have to run that 3000d at full tilt... you can run 2 kicker 8's on a saz 3000d
July 23, 200817 yr 1250 watts If you abuse them no they won't take it. If your sensible about it then sure...
August 6, 200817 yr I put 2 Havoc 12s on a 3000d in a Dodge Charger. Everything was good until the guy's idiot brother cranked up everything in the car labeled "bass". The little bastard even got in the trunk and cranked up the bass boost on the amp.But yes, they will work under the supervision of a responsible adult.
August 6, 200817 yr I got 1 saz1500d per coil and with self control iam able to not blow anythink up yet............hahahahahahaha
August 6, 200817 yr I put 2 Havoc 12s on a 3000d in a Dodge Charger. Everything was good until the guy's idiot brother cranked up everything in the car labeled "bass". The little bastard even got in the trunk and cranked up the bass boost on the amp.But yes, they will work under the supervision of a responsible adult...so what happened ..they didnt blow..a ..or they sounded like crap
August 6, 200817 yr I put 2 Havoc 12s on a 3000d in a Dodge Charger. Everything was good until the guy's idiot brother cranked up everything in the car labeled "bass". The little bastard even got in the trunk and cranked up the bass boost on the amp.But yes, they will work under the supervision of a responsible adult.People like that should be banned from touhing anything! Sounds like one of the guys at the local shop. lol Edited August 6, 200817 yr by todd.brust
August 6, 200817 yr local audio shop moto: bass up turn the bass up turn it up... gain... ummm i donno turn it up... did you turn the bass up... lets bridge it.
August 6, 200817 yr local audio shop moto: bass up turn the bass up turn it up... gain... ummm i donno turn it up... did you turn the bass up... lets bridge it...and than dont forget to turn the bass up...right
August 7, 200817 yr local audio shop moto: bass up turn the bass up turn it up... gain... ummm i donno turn it up... did you turn the bass up... lets bridge it...and than dont forget to turn the bass up...rightWhat did you say? I'm too mesmerized by your avatar to know what we're talking about right now
August 7, 200817 yr I put 2 Havoc 12s on a 3000d in a Dodge Charger. Everything was good until the guy's idiot brother cranked up everything in the car labeled "bass". The little bastard even got in the trunk and cranked up the bass boost on the amp.But yes, they will work under the supervision of a responsible adult.People like that should be banned from touhing anything! Sounds like one of the guys at the local shop. lolI was aware of this being a possibility so the amp is behind a trim panel secured by some security screws. I guess he was able to bend the panel back enough to get his fat arm in to turn up the bass boost.The boost was ALL the way up.
