Posted July 28, 200817 yr Ordering a AudioControl DQXS digital processor sometime in the near future. All the speakers I have are in my sig. I need suggestions on where to place these bad boys. Two 6.5"s are going into the bottom of each door. for the 4s and tweets do u fellas suggest I do 1. midrange/tweets in doors and a-pillars. 2. doors and kicks 3. kicks and A-pillars note: each 4 will have a tweet right beside it, so it wont be off axis
July 28, 200817 yr my friend has a mercedes kompressor and its stock system sounds really really nice, i think its doors and a pillars
July 28, 200817 yr Curious as to your car and drivers. <--obviously doesn't have sigs on and considering a lot of us don't posting some info would help
August 5, 200817 yr just for you M5"4* 0.75" Kenwoold silk dome tweets4* 4" Dayton midranges4* Mach5 MLI-65 (6.5" midbass)2* Loaded Fi BTL 12s first versions (dual 1ohm)COMMING SOON!!!!!!a Pete Kulicki blowthrough compressed bass reflex design and build4* Sundown SAZ-1500Ds1* AudioControl DQXS (Active 3way front staging)1* Rockford Power T4004 (4ch amp)1* Rockford Power T3002 (2ch amp)1* RemanMotorCity 250amp alt with MLA regulator1* Deka Intimidator 9A78DT (starter battery)3* Deka Intimidator 9A31s (rear batteries)2* 2/0 Welding cable runsClarion VRX785BT 7" Flip-out"I recently just got door pods built/done and i have both mid/midbass on the bottom of the door with the tweet high on the door. sounds pretty badass IMO Edited August 5, 200817 yr by EmperorJJ1
August 5, 200817 yr You should only need one mid and one tweet on each side, even to keep up with a pair of midbasses.
