I picked up a tdx 15 dual voice coil 2 ohm for $100 in a pre-fab box. 1200 watts rms. Hooked it up and found out the box is broke. It sounded like Donald Duck getting kicked in the nads.
I would like to build an spl box for it but after googling my fingers off I can't seem to find any box spec recommendations. I was hoping to find a simple slot port build or something because I am still a noob and don't quite understand the Qs's and the other mysterious letter number references on the tech sheets :)
Any ideas or opinions would be appreciated. I prefer spl over sq.
Edited by alvitae
Do you have the T/S parameters handy? It would help people get some ideas together.
Here goes. Not sure what it means, I hope the t/s's are in there. But as far as box building goes I'm a carpenter and understand dimensions and building techniques.
Diamond audio mailed this to me after I posted. So they recommend 1.65 cubic but I doubt thats optimum for spl.
spl-86.5
qms-3.5
qes-0.60
qts-0.51
fs(hz)-33
Vas(L)-22
cms-0.066
Mms-330
sd (m squared) 0.0487
BL(t.m)-21
Re(ohms)-3.85
xmax(mm)-24
Znom(series ohm)4
Vented enclosure
Vb-1.65 / 1.2
f3-33 / 38
fb-33
ports-1
port i.d.-4"
port length-12"
