Posted August 6, 200818 yr So i'm currently running a 12" Icon and while it's an awesome sub, Im wanting to go bigger already. I just want to push a lot more air. I'm pretty set on an 18" Fi BL or maybe 2 18" Q's. I'm wanting to feed it more power though also so Im thinking of either buying another 1000D and strapping them together, or selling my 1000D and picking up a 3000D. Would that be overkill? Ive got an Eddie Bauer Explorer(v8) and already have the Big 3 upgrade. I'll be picking up an Iraggi alt. and a Yellow Top as well. Would I need to run two batteries with this setup?
August 6, 200818 yr 3000 watts would be over kill imo on 1 bl or even 2 Q's but if you pick up a 3000d you will need more then one yellow top and a ho alt.
August 6, 200818 yr 3000 watts would be over kill imo on 1 bl or even 2 Q's but if you pick up a 3000d you will need more then one yellow top and a ho alt.3000 is over kill for 1 BL but not for 2 Q18s when you set it up correctly! Keep the Yellow Flop up front and throw a 100Ah+battery by the amp and your good. But remember, the more reserve power the better!
