Posted August 13, 200817 yr hello everybody, I'm new in the forum and I need some information about this amp Autotek 500.s, I just ge this amp to replace my system, but I didn't get any info on it, does anyone know something about it?thanks!
August 13, 200817 yr welcome to ssa. nice lincoln. did you already buy that amp?lets talk about other amps instead...... unless you already bought it.
August 13, 200817 yr Author thanks man............but no, I didn't buy it, I recive it as a gratitud for a favor, you know!!!!anyway, I'm about to start breaking my system and I was looking for information about this amp.the amps that I'm planning to buy are the Power Acoustik BAMF 1200/4 - 1600/4 - 5500/1D, and the subs also from them STW-10.already have the alternator upgraded to 325 amps, cause we use two way radios and those guys take a lot of currents every time you use them, also oredered 1/0 awg from Soundquest (my budget don't reach to high brands).so if you have any suggestion, I still haven't bought any amps, or any subs ( by the way, the subs have to be shallow mounted, cause I don't have that much space availabe, and I work as a carservice driver, so I need as much trunk space as possible).so I see that you have an LTC also, I use to have one of those in 2002, brand new, but i have to get rid of it cause it reach the 400,000 miles and was not good enough for the bussiness, so I'd love to see some pics of our ride, just send them over or where I can find them. Edited August 13, 200817 yr by joselmar
August 13, 200817 yr yeah mine is a lincoln towncar cartier L. mine has 425000 on it. still rolling no problems. what are your goals,budget and shopping list? o yeah.. where did you get such a high amp alt for that car? pics of my car are in the link just below my name in the sig,
August 14, 200817 yr Author my goal SQ, my budget $2,500.00 and still don't have shoppin list.this alternator I get it here with a friend that works in a junk yard of lincolns and fords, this baby was installed in a ambulance, but check the best part, I pay $75.00 fo it and $120 for set up ( with external digital voltage regulator ) and mounting. actually my system generate 15.3volts stable ( either 800 rpm or 6,000 )........that's the beauty of NY!!!!.anyway this is it, my budget is limited du to the latest financial situations but if I can't get something nice over the Internet before winter, I'll have to give it a try with the locals.by the way, I saw your car, that's crazy man, those are "big wheels", what did you do with the rear air suspention to fit those rims?also the trunk set up, very nice, I saw a pair of my dream subs the "Fi 12 btl", it must sound extemely nice and loud, the only thing I notice is that you have a lot of waste space all around the system, isn't thre any way to take advantage of it?, cause here when we install extra batteries for the two way system we use both rear corners, and for the amps we install them behind the seat on top of a nice fit piece of MDF board.well if you ever need something for your car like body parts, interior or mechanical, just pm or email, and I'll help you out with those, remember that here we have more town cars than any other state in the country, and the parts are very cheap.
August 14, 200817 yr Can you tell us more about the system and what you want? Do you want two 12's and a 1500 watt amp, 6.5" components up front and an amp for them, etc.? $2500 is quite a large budget for things we can come up with.
August 16, 200817 yr Author well the only problem is space, I need as much space as possible and this are the pictures of my carhttp://www.cardomain.com/my/edit_page?page_id=2979087so take a look at it and see what can be done in there with my budget.
