Posted December 20, 200420 yr what would be the specs of al the amps comming out...if you cant say now i understand... jamie
December 21, 200420 yr what would be the specs of al the amps comming out...if you cant say now i understand... jamie<{POST_SNAPBACK}> AUTO SOUNDAS75.2 75 x2@4OHM 300x1@2AS150.2 143X2@4ohm 600x1@2ohmAS75.4 63X4 @ 4OHMS XTREME SERIESXA-485 90x4@4ohm XA-4150 150x4@4ohmXA-2150 150x2@4ohm,[email protected] ohm stableXA-300d [email protected] stableXA-900D [email protected] stableXA-1500d [email protected] stableXA-3000d [email protected] stablethis is the power ratings given to the amps,all amps were tested at 13.3-13.7 i also belive there are more AS amps being released but i do not have the entire list,as soon as the sample Birth sheets are printed ill be sure to post them for you guys
December 21, 200420 yr Author what would be the specs of al the amps comming out...if you cant say now i understand... jamie<{POST_SNAPBACK}>AUTO SOUNDAS75.2 75 x2@4OHM 300x1@2AS150.2 143X2@4ohm 600x1@2ohmAS75.4 63X4 @ 4OHMS XTREME SERIESXA-485 90x4@4ohm XA-4150 150x4@4ohmXA-2150 150x2@4ohm,[email protected] ohm stableXA-300d [email protected] stableXA-900D [email protected] stableXA-1500d [email protected] stableXA-3000d [email protected] stablethis is the power ratings given to the amps,all amps were tested at 13.3-13.7 i also belive there are more AS amps being released but i do not have the entire list,as soon as the sample Birth sheets are printed ill be sure to post them for you guys<{POST_SNAPBACK}>thanks alot randyyour my boy blue
December 21, 200420 yr what would be the specs of al the amps comming out...if you cant say now i understand... jamie<{POST_SNAPBACK}>AUTO SOUNDAS75.2 75 x2@4OHM 300x1@2AS150.2 143X2@4ohm 600x1@2ohmAS75.4 63X4 @ 4OHMS XTREME SERIESXA-485 90x4@4ohm XA-4150 150x4@4ohmXA-2150 150x2@4ohm,[email protected] ohm stableXA-300d [email protected] stableXA-900D [email protected] stableXA-1500d [email protected] stableXA-3000d [email protected] stablethis is the power ratings given to the amps,all amps were tested at 13.3-13.7 i also belive there are more AS amps being released but i do not have the entire list,as soon as the sample Birth sheets are printed ill be sure to post them for you guys<{POST_SNAPBACK}>thanks alot randyyour my boy blue <{POST_SNAPBACK}>
December 22, 200420 yr Author what would be the specs of al the amps comming out...if you cant say now i understand... jamie<{POST_SNAPBACK}>AUTO SOUNDAS75.2 75 x2@4OHM 300x1@2AS150.2 143X2@4ohm 600x1@2ohmAS75.4 63X4 @ 4OHMS XTREME SERIESXA-485 90x4@4ohm XA-4150 150x4@4ohmXA-2150 150x2@4ohm,[email protected] ohm stableXA-300d [email protected] stableXA-900D [email protected] stableXA-1500d [email protected] stableXA-3000d [email protected] stablethis is the power ratings given to the amps,all amps were tested at 13.3-13.7 i also belive there are more AS amps being released but i do not have the entire list,as soon as the sample Birth sheets are printed ill be sure to post them for you guys<{POST_SNAPBACK}>thanks alot randyyour my boy blue <{POST_SNAPBACK}> <{POST_SNAPBACK}>hey randy i see you have two ohm ratings, (what gives)so its 3000w @2ohm or 1ohmis the 1ohm for burps or daily
December 22, 200420 yr what would be the specs of al the amps comming out...if you cant say now i understand... jamie<{POST_SNAPBACK}>AUTO SOUNDAS75.2 75 x2@4OHM 300x1@2AS150.2 143X2@4ohm 600x1@2ohmAS75.4 63X4 @ 4OHMS XTREME SERIESXA-485 90x4@4ohm XA-4150 150x4@4ohmXA-2150 150x2@4ohm,[email protected] ohm stableXA-300d [email protected] stableXA-900D [email protected] stableXA-1500d [email protected] stableXA-3000d [email protected] stablethis is the power ratings given to the amps,all amps were tested at 13.3-13.7 i also belive there are more AS amps being released but i do not have the entire list,as soon as the sample Birth sheets are printed ill be sure to post them for you guys<{POST_SNAPBACK}>thanks alot randyyour my boy blue <{POST_SNAPBACK}> <{POST_SNAPBACK}>hey randy i see you have two ohm ratings, (what gives)so its 3000w @2ohm or 1ohmis the 1ohm for burps or daily<{POST_SNAPBACK}>its 1 ohm stable daily,its 3000 at 2 ohms(accually somewhere in the realm of 3080 watts @ 2 ohm) if ya want more run it at 1 but we rated at 2 so it can be matched up to 2 xs15d1v.2 when i dropped the amp to 1 ohm i kept smoking all my test equipment, like i said when i get the rating sheets ill post them for you i already turned them into print so i dont have all the ratings sitting in front of me but youll be the first to know them when i get them back
December 22, 200420 yr that excites me.<{POST_SNAPBACK}> <{POST_SNAPBACK}>steady 3k @ 2 while still being able to drop below for shows.... excites me. B)
January 12, 200520 yr cross fingers<{POST_SNAPBACK}> wonder what the price would be on the xa-3000d 3000 watts @ 2 ohms nice i run 4 xs-15dv.2 at 1.7 ohms all together ..hmmmm i want 2 of them 1 for each pair of subs ... question what is that sub next to the xs with the basket sticking out .looks like a helmet.
January 13, 200520 yr nice to see the 3000 . i heard about it back in nov. it will be even better to see 8 of then in my car replaceing the 8 vfl150.1s.
January 24, 200520 yr Is there any way to get a 4 ohm rating on the big amps? Im looking for a nice 1200-1800watt amp that has like a 300-400 4 ohm rating.Im doing usac 301-900 class.
January 24, 200520 yr Is there any way to get a 4 ohm rating on the big amps? Im looking for a nice 1200-1800watt amp that has like a 300-400 4 ohm rating.Im doing usac 301-900 class.<{POST_SNAPBACK}>900d1700 maxrms 900 @1ohmrms 600 @2ohmrms 300 @4ohmyou can drop all the amps down to a 1/2 ohm for burps without much problem,but i wouldnt run them daily that way
January 25, 200520 yr Is there any way to get a 4 ohm rating on the big amps? Im looking for a nice 1200-1800watt amp that has like a 300-400 4 ohm rating.Im doing usac 301-900 class.<{POST_SNAPBACK}>900d1700 maxrms 900 @1ohmrms 600 @2ohmrms 300 @4ohmyou can drop all the amps down to a 1/2 ohm for burps without much problem,but i wouldnt run them daily that way<{POST_SNAPBACK}>1700@ what ohm?
January 25, 200520 yr nice to see the 3000 . i heard about it back in nov. it will be even better to see 8 of then in my car replaceing the 8 vfl150.1s.<{POST_SNAPBACK}>hum wouldn't that just open up a new can of woop azz for the competition in the lanes for ya .
