Posted August 22, 200817 yr Ok well the old setup is in the Sig. New setup will consist of.H/U - Still chitty sony oneFront Stage: 2 Sets of PG RSD'sFront Stage amp: Sundown 100.4Sub Stage: 2 18" Fully loaded Fi BL's dual2'sSub Amp: Sundown Saz3000d @ .5Electrical: 4 Deka Intiminators and a 250 amp Mechman altWiring: Kicker hyperflexSo far I got 2 Dekas and an 18" BL on the way. First pic there 2 of the batteries the 3rd should make it a perfect fit all the way across and the 4th battery will be under the hood.
August 22, 200817 yr how many amp hours are each of those yellow guys. ur gonna run at .5 ohms daily?
August 22, 200817 yr Yep I am gonna run it daily. Volts should be staying above 12.8your gonna make me search for the amp hours arnt you... alright what is the model number on those cells. im shoppping too
August 22, 200817 yr Author HA Ill find it for ya. Here ya go.Specifications: * Part Number : 9A31 * BCI Group Size : 31 * Voltage : 12 * Cold Cranking Amps @ 0
August 22, 200817 yr HA Ill find it for ya. Here ya go.Specifications: * Part Number : 9A31 * BCI Group Size : 31 * Voltage : 12 * Cold Cranking Amps @ 0
August 22, 200817 yr Author Got them for 160 each. I am actually gonna hook the batteries back up and hook my BL's back up and see what voltage drops to on these batteries. When I had the kinetik 1400 under the hood and 2400 in the rear I dropped to like 11.8 Lets see what these drop to.
August 22, 200817 yr o'riley and carquest get thier agm batts from deka and are supposed to be off the same build line, just an fyi
August 22, 200817 yr Author Whats in his hand?18" BL! Sitting next to the 15" Which is for sale but no one is buying :verymad:
August 22, 200817 yr Whats in his hand?18" BL! Sitting next to the 15" Which is for sale but no one is buying :verymad:swqeeeeeettt
August 22, 200817 yr Whats in his hand?18" BL! Sitting next to the 15" Which is for sale but no one is buying :verymad:Haha, I bet you were waiting ALL day long just waiting for the UPS guy...
August 31, 200817 yr how much are you wanting for that 15" bl? my friend mite be interested in buying it.
September 4, 200817 yr Author UPDATED GOT ANOTHER G31 DEKA AND MY 34 FOR UNDER THE HOOD! THE BATTERY BANK IS COMPLETE! Edited September 4, 200817 yr by SEC
September 6, 200817 yr Author Well new subs are in got a deal on some RD Alpha V.2's so I am going with them. Should be better on the low end response then the BL's and I like being loud at low frequencies =D Edited September 6, 200817 yr by SEC
September 6, 200817 yr holy cow. 600+ amperage hours for a single 3000d. all i gotta say is.......................good job on the electrical. do it right or dont do it at all.
September 6, 200817 yr Author holy cow. 600+ amperage hours for a single 3000d. all i gotta say is.......................good job on the electrical. do it right or dont do it at all.Yep I wanna keep my volts up as high as possible. Edited September 6, 200817 yr by SEC
September 6, 200817 yr Author Battery bank is done! Its late so the pics are kinda dark. I will get a pic of the 34 under the hood tommorow. Edited September 6, 200817 yr by SEC
September 6, 200817 yr Author Also my front battery is charging 13.9 but the rears are charging at 13.7 is that bad? Or is it just because of current loss going from the front to rear.
September 6, 200817 yr D@mmmmmm Hommie i like the way you Rollllllllllllllllllllllll lets see the boxxxxxxxxxx
September 6, 200817 yr Box will be done tommorow! Got a buddy of mine building it!Size ?port Freq ?you got a Wicked Start off topic:did you see the Custom 18" im having built ?
September 6, 200817 yr Author Ya I saw it! Its a beast! Ya let me post pics up of the design of my box. Edited September 6, 200817 yr by SEC
