June 1, 200917 yr Author Just to give you an idea of how big that port is.Don't judge me.The leads were too short for me to face them the right way, FTL. These subs are AMAZING.It'll play music all the way down to 23hz, even being tuned at 35hz. Edited June 1, 200917 yr by Bigpimpin91
June 5, 200917 yr hey .. could i ask a favor.?? any chance of measureing at the b piller on your truck? floor to roof? im thinking about doing one of thse for 100% spl . dunno how well i can stack 18s..
June 6, 200917 yr Author hey .. could i ask a favor.?? any chance of measureing at the b piller on your truck? floor to roof? im thinking about doing one of thse for 100% spl . dunno how well i can stack 18s..You're not going to do 18's in this truck for SPL.Stick with 15's, even then it's cutting it close.It's ~36".The roof isn't perfectly straight.
June 7, 200917 yr Author First Burp is 35hz.Second is 29hz.Third is 23hz.Fourth is 33hz. (My Peak.)Fifth is 34hz.Sixth is 45hz.Last one is some bass race practice.Got a perfect 39.9 and decided to crank it. Forgot I had the Zune turned down. And my drivers window fell down. (Soulja Boy - Rubber Bands)That annoying ass wail is my alternator belt.V-Belt FTL. name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"></embed></object>"> name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"></embed></object>" type="application/x-shockwave-flash" wmode="transparent" width="650" height="535">He's another short little vid for you guys. name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"></embed></object>"> name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"></embed></object>" type="application/x-shockwave-flash" wmode="transparent" width="650" height="535"> Edited June 7, 200917 yr by Bigpimpin91
June 11, 200917 yr As far as your belt issue, you need a new belt. but there is some very hand stuff call belt dressing which is made by a company called Gunk , itl be in an orange and white can at your local auto store or Walmart. The downfall to using it is it is just a temporary fix for the squealing, and your alt probably isn't able to work at its full capability with your belt slippen. BTW are you still runnen the fusion amps on the AQ's? if so I believe they are pushen the subs allot better then i thought.
June 11, 200917 yr Author As far as your belt issue, you need a new belt. but there is some very hand stuff call belt dressing which is made by a company called Gunk , itl be in an orange and white can at your local auto store or Walmart. The downfall to using it is it is just a temporary fix for the squealing, and your alt probably isn't able to work at its full capability with your belt slippen. BTW are you still runnen the fusion amps on the AQ's? if so I believe they are pushen the subs allot better then i thought.Oh hell no.Running an Audiopipe 3k @ 2Ω.Going to run it at 1/2Ω bridged for the hell of it. I'll get it replaced if it pops.I've tried tightening this thing up so many times.This belt isn't even that old. I'll try that one stuff though, thanks!
June 11, 200917 yr Going to run it at 1/2Ω bridged for the hell of it. I'll get it replaced if it pops.It won't run 1/2 ohm bridged..... well atleast if it's built like the massives. the massive's will go directly into protect (which is how the protection should work)
June 12, 200917 yr Author Going to run it at 1/2Ω bridged for the hell of it. I'll get it replaced if it pops.It won't run 1/2 ohm bridged..... well atleast if it's built like the massives. the massive's will go directly into protect (which is how the protection should work)I've seen it done before on really shitty electrical.And a buddy of mine is running his at 1/2 daily.
June 12, 200917 yr hey .. could i ask a favor.?? any chance of measureing at the b piller on your truck? floor to roof? im thinking about doing one of thse for 100% spl . dunno how well i can stack 18s..You're not going to do 18's in this truck for SPL.Stick with 15's, even then it's cutting it close.It's ~36".The roof isn't perfectly straight. dang only 36 tall? that sucks.. i just love 18s.. lol wonder if i could do them in a BP though
June 15, 200917 yr Author hey .. could i ask a favor.?? any chance of measureing at the b piller on your truck? floor to roof? im thinking about doing one of thse for 100% spl . dunno how well i can stack 18s..You're not going to do 18's in this truck for SPL.Stick with 15's, even then it's cutting it close.It's ~36".The roof isn't perfectly straight. dang only 36 tall? that sucks.. i just love 18s.. lol wonder if i could do them in a BP thoughEasy fix.Clamshell.
July 26, 200917 yr Author Got my Damplifier in.Not only did Second Skin giveaway the product itself, I noticed a rattling inside the box when the UPS guy handed it over.Popped it open, they threw in the roller AND the Buzz Thompson Fury Folding Knife!Way to pucking go, and thanks!Installation will happen hopefully sometime this weekend.I don't have a day off until Sunday so probably then.Pics for Now.That brown box underneath is my recone.
July 26, 200917 yr Author While at the hardware store today, I noticed a Car Show across the street at the Donut Castle.Snapped a few pics.Onto Bidness.Box gone.Headliner Gone.Peeled the insulation and what's this, oh the pucking roof brace separated from the roof.Nothing a little of this won't fix.
July 26, 200917 yr Author The spreaders we had were too big, time to improvise.Internal wiring Done.This is the local competitor I am working with, he has a 97 Escort, won't been done until Octoberish.Here's some pics.Gutted, waiting for steel. :ph34r: Here's a little Hint.Piece of 1x1 for baffle bracing.Battery Rack with 3 Wal-Mart specials.Doubles as an amp rack.
July 26, 200917 yr Author I know the subs look out of phase in the first video but that is because the drivers side sub is broken in and the passengers is the fresh recone. pucking Gorilla Zoe - Money (35hz FTL.)Just cruising home, cranked it because I was trying to unwind.Look in the rear view noticing it seemed to be moving more than usual, and then it fell.
August 22, 200916 yr Sorry to bring back such an old post, but What app are you guys using to make box diagrams like this????
August 22, 200916 yr Sorry to bring back such an old post, but What app are you guys using to make box diagrams like this????looks like google sketch up
