Posted August 30, 200817 yr Center located port, double baffle on the front. Pretty straight forward. Customer wants white port and black carpet. Should look nice when complete.
August 30, 200817 yr Whats this made out of? looks like MDFPezTrupan Light, its lighter and easier on his tools than MDF, but more expensive.
August 30, 200817 yr I was thinking,since this box were built on the small in of Fi audio recommendation,can add sum polyfill,so my Bl 12'' would perform as if it were in a larger box? Ilisten to alot of old school R& B and a litter hip-hop, it would be driven by a 2000 rms amp?? Thanks inadvance!!!!!
September 2, 200817 yr Author I was thinking,since this box were built on the small in of Fi audio recommendation,can add sum polyfill,so my Bl 12'' would perform as if it were in a larger box? Ilisten to alot of old school R& B and a litter hip-hop, it would be driven by a 2000 rms amp?? Thanks inadvance!!!!!Yes, by adding polyfill, it is supposed to make the driver perform like its in a slightly larger enclosure. You can always try it both ways, and just pick which you like better.
June 3, 201114 yr how much would a box like this run me? but id want it about 16in high and maybe a little smaller on the length or depth
