Posted September 1, 200817 yr I have 2 dual 12" Alpine Type R's...I've been told that ported is the way to go for these subs.There is a problem though. My trunk is small as well as the trunk opening. Right now I have a crappy sealed box 38"W x 10" TD 14" BD x 14" H...it has two old MTX subs in it right now.It was a pain to get in because the height of my trunk opening is 14" as well and the width is 35".I've made a few designs in photoshop but I'm not sure if they'd work due to my lack of knowledge in this area:I'm not sure how many cubic feet will be needed but I'd like the width to be around 30" and the height to be less than 14".Again...these are just some ideas...not sure if they'd work...I'm sure theres alot of really good designs out there but I just need something that can fit.
September 1, 200817 yr We can definitely build something like that for you. What I would need you to do, is take some max dimensions (largest you can fit INTO the trunk opening), and get with my designer, Chris (at) fishercustoms (dot) com.If you have any other questions, just let me know.
September 1, 200817 yr Author Just to let you know I drive an 08 Pontiac G5 and my battery is in the back underneath the removable flooring. Ok I measured and took pics...also edited a design and posted it below...now my opening is kind of roundish so I think a smaller box for both height and width would be best and I would try to make up cubic feet with depth.So the bottom two designs I made would probably be best unless I have a rectangular box with the subs on top.If I can get the box to be about 29-30" wide and 13" high I would be able to move it all the way back until it touches the seat which I can't do with my current one. Now if I put the box in thru teh backl seats I could probably get a height of 14-15" BUT the box would have to be 30" wide or less. That would provide an extra 6-7" of depth (actually the ruler goes back about 8 or 9" but I have to do more measuring to see if it's ok) without losing any trunk space. Right now the box I have has a bottom depth of 14" and a top depth of 10" so I could make the new box 20" or so in bottom depth.I have no idea what the cubic feet of this new box would be...I'm sure it would still probably be too small.
September 2, 200817 yr Author So can we work something out? I sent an e-mail to 'Chris' and haven't gotten a reply back yet to my last e-mail.
September 2, 200817 yr I emailed you back yesterday. Did you not get it?Chris' internet is down. He sent me a couple designs from a family members house this weekend, and also told me about his computer problems. Im sure you will hear from him shortly.
September 2, 200817 yr Author It went to my spam inbox for some reason. Sorry. I'll just wait for his reply I guess.Is everything set at a certain price for cubic feet? What I mean is there any extra charge for a design like mine?Also, Alpine's online manual for Type R's says the most cubic feet an enclosure should be for 1 Type R is 1.75 cubic feet....I have two so that would be 3.5...is that too small though or no? Edited September 2, 200817 yr by dirtTHIRTY
September 2, 200817 yr Design will play a factor in the price as well.I would go a little larger with the R's. 2.25-2.5 per driver seems to be very popular.
September 2, 200817 yr Author Design will play a factor in the price as well.I would go a little larger with the R's. 2.25-2.5 per driver seems to be very popular.Wow...I doubt I'll even be able to get a box that size in my trunk.
September 2, 200817 yr Dirt,I was just looking at you diagram. It would scare me to death to have an enclosure built with lengths and widths quoted with " Maybe"Do you mean "maybe" is the maximum your trunk will allow or is "maybe" meant...Maybe it wont fit?I know its close as my Sons Lexus is tight too, but if anybody can do it...B.J. can.When Chris gets back to you, be sure you have done your homework on measuring so that you can be sure you dont have an enclosure sent to you that it 1 inch from fitting in the trunk.I hope Im not sounding like a jerk, just wanting to help you since I went through the same scenario.How about just measure your trunk dimensions and let Chris know what they are and he can assist you that way?If you only tell him the box dimensions, then thats all he has to go on.You most definitely want this enclosure custom made by FC, because its the only way to get fittament and air space you need. Odds on a store bought generic box either fitting / sounding good are 1000 to one. Edited September 2, 200817 yr by MikeMartin
September 3, 200817 yr Author Ok I think we might have something here.Without the slanted front part the box would be 13"H x 24"D x 34" WNow assuming you use 3/4" MDF the cubic feet would be 4.87. (11.5 x 22.5 x 32.5)Now the cubic feet of that slant is 0.73 (6 x 12.5 x 34 / 2 / 1728, didnt take out MDF thickness)4.87 - 0.73 = 4.14...that should be good enough shouldn't it?Then put the Alpine logo (26" x 3.25") on the front...centered. Edited September 3, 200817 yr by dirtTHIRTY
September 3, 200817 yr Ok I think we might have something here.Without the slanted front part the box would be 13"H x 24"D x 34" WNow assuming you use 3/4" MDF the cubic feet would be 4.87. (11.5 x 22.5 x 32.5)Now the cubic feet of that slant is 0.73 (6 x 12.5 x 34 / 2 / 1728, didnt take out MDF thickness)4.87 - 0.73 = 4.14...that should be good enough shouldn't it?Then put the Alpine logo (26" x 3.25") on the front...centered.Did you subtract the port area and driver displacement when you figured your net volume?
September 3, 200817 yr Author Did you subtract the port area and driver displacement when you figured your net volume?No
September 3, 200817 yr Did you subtract the port area and driver displacement when you figured your net volume?No Oops, what does that leave you?
September 3, 200817 yr Did you subtract the port area and driver displacement when you figured your net volume?I meant port volume, not area.
