Posted December 27, 200420 yr I'm just curious without the ac converterr, what would happen if I cut the power wire and connected it to the battery, or a 12 volt connection.Would itA. burn up the ps2B. Not get ebough powerC. work just fine.I say B
December 27, 200420 yr Admin you could easily damage the PS2, because you will be sending it direct current, when it is expecting alternating
December 27, 200420 yr Author ah, that is true also.Kinda forgot that a battery is DC, oh whoa is me.But its not like i was going to do it anyway, i already got powe converters, lol
December 27, 200420 yr Actually, I think the PS2 has a power supply inside it similar to a computer. Should be as simple as bypassing that and getting the necessary 12 and 5 volts DC and you should be good. There are many power supplies out there for CarPcs right now that should be able to handle this adequately, but I am just guessing on this. I am not at all familiar with the electronics. But if you find something out, let me know as I have been studying this for a while and always come to a dead end. I will NOT use a converter in my vehicle.I wonder if Dave Edwards would know.
