i need a little help with my set up.
ok.
I drive a 1998 cadillac deville, Phase linear uv8 head unit. Im getting a fully loaded 18" FI BTL and a rockfordfosgate T2000 amp. I have a yellow top under the hood. I will probly get a kicker 1/0 wiring kit or some other 1/0 wireing kit. What eles will i need??
i would add a battery isolator and another yellow top. in a pinch you can put a normal starting battery up front for now and mover the yellow top to the rear to avoid buying another battery. i'd get some extra 0 gauge then what they give you with a kit so you can do the big 3 upgrade, and also some good cable for the sub, at least 12 gauge or better, maybe 8 gauge power cable. other then that, proper enclosure, decent RCA cables, and some sound deading for the trunk if you want to do it right.
you think that a car audio shop nows how to do the big 3? ive looked at how to do it and i know some how ill mess somthing up lol.
they should, or a normal mechanic/garage may be able to do it for less $$$
ok cool. thanks for the help. :D got a couple shops around here that are well know. ones a rockfordfosgate place(will probly get it done there) and ones a jl audio place. I just cant wait to get my system ive been waiting years lol.
even if they don't know how just tell them what you want installed...
Also i would recommend keeping the yellow up front and getting a kinetik or powermaster for the trunk....
up grade your front speakers:P
ok.
You need to make sure you have someone who can fit a 10cuft box in your trunk. Good luck with that.
it doesnt need to be 10cuft feet. it says 5-8..... Im trying to selling my caddy and get some type of suv. even if i dont the trunk is huge could fit probly 10+bodies in there.
Actually it says 5-10cuft. The sub takes .26 cuft and the port will take a few cubic feet as well. I'd also recommend going as big as possible which in reality means you are going to need more than 10cuft...
