Posted September 3, 200818 yr Hey, I just bought a whole bunch of twisted speaker wire for my install. 8-16AWGhttp://www.knukonceptz.com/productMaster.c...Speaker%20KableI have no idea how I splice it to be able to attach female disconnects or screw the individual wire into adapters. Edited September 3, 200818 yr by b34tBoX
September 3, 200818 yr It's no different than any other wire out there. Remove the outside clear layer, remove insulation...
September 4, 200818 yr Author It's no different than any other wire out there. Remove the outside clear layer, remove insulation...Oh OK, I see what you mean, I didn't realize that the outer clear coating was separate.I'm gonna have to pick up some tools now.
September 5, 200818 yr Author How would I go about stripping the larger speaker wire covers (8AWG) which is about the same diameter as 0AWG.Also, what do I use to strip 0 and 4AWG power wire to prepare it for a crimp-on connector. Edited September 5, 200818 yr by b34tBoX
September 5, 200818 yr I've found that the same coax cable strippers that satellite TV installers use, seems to work well for 8awg/4awg wire. For 0awg, utility knife.
September 5, 200818 yr Author Ever see an utility knife before?Yeah, I just thought there would have been a cleaner way to do it. Especially for the twisted speaker wire.I'll give it a go then.
September 5, 200818 yr anything smaller than 12 gauge I use my wire strippers. Anything bigger I use my knife. Just need something with a sharp edge, you know.
September 5, 200818 yr I use a knife for any wire...that's because I can never find my wire stripper when I need it
