September 20, 200818 yr Author Thanks alot mate! great help, you've pushed to comps now lol!do you recommend any? or have experience with
September 20, 200818 yr Author "D Bumpy!That work well with SAX 100.2i realise these are more to personal preferences, but still.!
September 20, 200818 yr Author Sorry Double.But anyway, dont worry about budget just not anything to crazy Edited September 21, 200818 yr by Pezzaboi
September 21, 200818 yr Sorry Double.But anyway, dont worry about budget just not anything to crazynever heard hybrid Audio but heard good things.can also look into cdt, hertz, morel,dls focal and the likes...seas also not bado and passive is the way to go if ur a noob and way easier to get right
September 21, 200818 yr Author Ok 8], it sounds harder to me!Saved me a bit of money on the amp tho,Erm could anyone just tell me if these amps come with wiring?and any news on rear speakers
September 21, 200818 yr Rear speakers will make your system worse across the board and do nothing good. Waste money if you like.For $250 the Pioneer 720 prs set is nice.
September 22, 200818 yr Ok 8], it sounds harder to me!Saved me a bit of money on the amp tho,Erm could anyone just tell me if these amps come with wiring?and any news on rear speakersamps dont come with cables but you can normally get the cables for less if you buy a amp from a audio shop. forget the rear speakers bro unless you watch 5.1 DVD's or have a very long truck or car
September 22, 200818 yr Author well i plan on getting the sundown 1000 amp... of 1200 if i can!so will have to be orderd online because im from the UKi'm forgetting the rear speakers last on my list is electrics, to sort out. really dont want more batteries and stuff, i need to find out what ALT i have. Won't be that big i suppose.you defo recommend 0 Gauge?
September 22, 200818 yr Author OK dudes!im going to build my own box, should be easy as im an apprentice Joiner 8]if i build out of MDF 20" length 20" width and 11" depth, made of 3/4" MDF the internal measurements should be 18.5", 18.5", 11"So! 18.5 x 18.5 x 11 = 3764.75 / 1728 = 2.17 Cubic feet. The sub takes up 0.19 Cubic Foot which leaves it at 1.98 Cubic foot?Can someone please check this over? my first go and hope to build on friday!thanks alot, i can get more info if needed
September 23, 200818 yr OK dudes!im going to build my own box, should be easy as im an apprentice Joiner 8]if i build out of MDF 20" length 20" width and 11" depth, made of 3/4" MDF the internal measurements should be 18.5", 18.5", 11"So! 18.5 x 18.5 x 11 = 3764.75 / 1728 = 2.17 Cubic feet. The sub takes up 0.19 Cubic Foot which leaves it at 1.98 Cubic foot?Can someone please check this over? my first go and hope to build on friday!thanks alot, i can get more info if neededmaybe you can try http://www.soundsolutionsaudio.com/home/in...calculatorflashlet us know how it turn out.what are you tuning to?
September 23, 200818 yr mmm alpines are nice im buying some 5x7 oval speakswtf? that has to rank up there with one of the dumbest posts ever. and a double one at that
September 23, 200818 yr mmm alpines are nice im buying some 5x7 oval speaks_BAN_ double negative doent make it right, but then again whatever tickles your fancy at the end of the day that is all that matters
September 23, 200818 yr Author Sorry the box is going to be sealed, so it doesn't need tuning right ?Hmm the sealed calculator gives a different answer :SDo i go by the calc! or the some: Height x Width x Depth / 1728 = Box volume in Cubic Feet?just in case the calculator is wrong
September 23, 200818 yr Author Sorry sorted it,Going to be 20 inch L, 20 inch W, 13 inch D, using 3/4" MDF, which gives the box 2.08^3 if you ask meDon't tune a sealed box do you?
September 23, 200818 yr Author Can anyone answer the questions above :SAnd also if you can!if you were to buy an Fi Q 15" with a Sundown 1000dWhat amp install kit and what else would you get from erehttp://www.knukonceptz.co.uk/productMaster...allation%20Kitsbits a bobs please
September 23, 200818 yr you do not tune a sealed enclosure. I would run 0/ guage to a dist. then to 4 guage each amp.
September 23, 200818 yr Author No i didnt think so,Could you recommend a package from somewhere for me to order, or packages. which should include all that i will need to wire it upNp's if you cba
September 23, 200818 yr Sorry sorted it,Going to be 20 inch L, 20 inch W, 13 inch D, using 3/4" MDF, which gives the box 2.08^3 if you ask meDon't tune a sealed box do you?You need internal volume, not sure on your math there:Internal with a single layer of 3/4" based on 20/20/1318.5*18.5*11.5 = 3935 / 1728 = 2.27 cuftSubtract any bracing and the sub to get your actual internal. A double baffle wouldn't hurt either, but unless I knew which was top it'd be hard to give you that number.Shop for wiring at Knukonceptz.com
September 23, 200818 yr Author MY BAD!I forgot to say that i took out the sub room! which is 0.19 ^3 on the 15"Sorry!yeh im looking on there now.http://www.knukonceptz.co.uk/productDetail...?prodID=KLM-AK0 - i've looked at this, i believe it covers all i need to install my amp.http://www.knukonceptz.co.uk/productDetail...?prodID=KAR08SS - and this to connect subs to the ampJust need someone to check it for me really before i make a big mistake.!
September 24, 200818 yr Author Basically i will need0/1 from + power to amp?a ??? size fuse with in 18" of the batt (What is the rating on the amp?) SAZ 1000dGround wire the same size as power? running to chassisI need a dist block?
