Thanks alot mate! great help, you've pushed to comps now lol!
do you recommend any? or have experience with
  • Replies 188
  • Views 18.2k
"D Bumpy!
That work well with SAX 100.2
i realise these are more to personal preferences, but still.!
Sorry Double.
But anyway, dont worry about budget just not anything to crazy
Edited by Pezzaboi
Sorry Double.
never heard hybrid Audio but heard good things.
can also look into cdt, hertz, morel,dls focal and the likes...seas also not bad
o and passive is the way to go if ur a noob and way easier to get right
Ok 8], it sounds harder to me!
Saved me a bit of money on the amp tho,
Erm could anyone just tell me if these amps come with wiring?
and any news on rear speakers
amps dont come with cables but you can normally get the cables for less if you buy a amp from a audio shop. forget the rear speakers bro unless you watch 5.1 DVD's or have a very long truck or car
well i plan on getting the sundown 1000 amp... of 1200 if i can!
so will have to be orderd online because im from the UK
i'm forgetting the rear speakers :)
last on my list is electrics, to sort out. really dont want more batteries and stuff, i need to find out what ALT i have. Won't be that big i suppose.
you defo recommend 0 Gauge?
OK dudes!
im going to build my own box, should be easy as im an apprentice Joiner 8]
if i build out of MDF 20" length 20" width and 11" depth, made of 3/4" MDF
the internal measurements should be 18.5", 18.5", 11"
So! 18.5 x 18.5 x 11 = 3764.75 / 1728 = 2.17 Cubic feet. The sub takes up 0.19 Cubic Foot which leaves it at 1.98 Cubic foot?
Can someone please check this over? my first go and hope to build on friday!
thanks alot, i can get more info if needed
OK dudes!
maybe you can try
http://www.soundsolutionsaudio.com/home/in...calculatorflash
let us know how it turn out.
what are you tuning to?
mmm alpines are nice im buying some 5x7 oval speaks
_BAN_ double negative doent make it right, but then again whatever tickles your fancy at the end of the day that is all that matters
Sorry the box is going to be sealed, so it doesn't need tuning right ?
Hmm the sealed calculator gives a different answer :S
Do i go by the calc! or the some: Height x Width x Depth / 1728 = Box volume in Cubic Feet?
just in case the calculator is wrong
Sorry sorted it,
Going to be 20 inch L, 20 inch W, 13 inch D, using 3/4" MDF, which gives the box 2.08^3 if you ask me
Don't tune a sealed box do you?
you do not tune a sealed enclosure. I would run 0/ guage to a dist. then to 4 guage each amp.
No i didnt think so,
Could you recommend a package from somewhere for me to order, or packages. which should include all that i will need to wire it up
Np's if you cba :)
Sorry sorted it,
You need internal volume, not sure on your math there:
Internal with a single layer of 3/4" based on 20/20/13
18.5*18.5*11.5 = 3935 / 1728 = 2.27 cuft
Subtract any bracing and the sub to get your actual internal. A double baffle wouldn't hurt either, but unless I knew which was top it'd be hard to give you that number.
Shop for wiring at Knukonceptz.com
MY BAD!
I forgot to say that i took out the sub room! which is 0.19 ^3 on the 15"
Sorry!
yeh im looking on there now.
http://www.knukonceptz.co.uk/productDetail...?prodID=KLM-AK0 - i've looked at this, i believe it covers all i need to install my amp.
http://www.knukonceptz.co.uk/productDetail...?prodID=KAR08SS - and this to connect subs to the amp
Just need someone to check it for me really before i make a big mistake.!
Basically i will need
0/1 from + power to amp?
a ??? size fuse with in 18" of the batt (What is the rating on the amp?) SAZ 1000d
Ground wire the same size as power? running to chassis
I need a dist block?
