Posted September 12, 200818 yr I just bought a 12" RL-s and need to begin to think about the box. I'm stuck between going sealed or ported. I think I want to do ported but if sealed is best for this driver, then so be it. If I do go ported, I'm thinking right now trying 3cuft tuned to 28hz and if I go sealed, I'm thinking around 2.5 cuft or so (going by SS recommendations). Is 28hz too low or should I go higher? Another question I can throw in here is for power. Single 3 ohm kinda sucks but can be dealt with. Right now I'm thinking about buying a JBL BPX1100.1 (http://www.sonicelectronix.com/item_10482_JBL+BPX1100.1.html) or an older Orion 2500D which I think does somewhere around 1200rms at 3ohms. Anyone have an other amp suggestions for this sub?Thanks fellas.
October 6, 200818 yr If one goes by the SS recommendation of 2.5 ft^3 for sealed, where does that land you in way of Qtc and F3?And if you want to play around yourself with some software and the rather odd T/S parameters for this driver, how do you go around doing it?
