July 2, 200422 yr I will still be using the RE MT 18's thats for sure, there isnt a woofer on the market that is louder in my setup and I have tried them all! But that is all I can say about the van until you guys see it at finals. I nned to keep a couple things under wraps until everything is worked out and I see if it works. Thanks. If anyone has any other questions just let me know.
September 10, 200422 yr Dang, I feel small , but anyway.....I'm doing a 15" PBX with a Cadence A7hc; MECA S2. Top so far this year, at a show, 143 on the TL. At my inlaw's house with the Brahma I did a 145 and some change when MattJ and I got our TL. From then on at every show it did consistant 142's....wtf...p'd me off! With the PBX my best is 143.
October 11, 200421 yr so how did everybody do now that the season is coming to a close?for me personally, i need to squeeze another solid db out of the cavy before meca finals. it's been a blast though
October 22, 200421 yr I did real chitty...12" HC3.82 cubes @ 32 hz, 42 square inches of port138.6 outlawBTW: How did you fit 9 cubes in a cavalier?
October 22, 200421 yr I did real chitty...12" HC3.82 cubes @ 32 hz, 42 square inches of port138.6 outlawBTW: How did you fit 9 cubes in a cavalier?<{POST_SNAPBACK}>http://www.sounddomain.com/memberpage/595073
November 12, 200421 yr Dang, I feel small , but anyway.....I'm doing a 15" PBX with a Cadence A7hc; MECA S2. Top so far this year, at a show, 143 on the TL. At my inlaw's house with the Brahma I did a 145 and some change when MattJ and I got our TL. From then on at every show it did consistant 142's....wtf...p'd me off! With the PBX my best is 143.<{POST_SNAPBACK}>i am runnin 2 15 pbx in a 9 cube box ported to 50 hz .... in a caravan and hitting 150.9 on the audiocontrol not yet tested on the term lab ...and runnin 2000 rms to them with a memphis mojo 2000d....
