Posted September 17, 200818 yr Ok, when I bought my speaker from my friend he gave it to me in this small, crappy made sealed enclosure and i need to take the apeaker out, not necessarily right away, but eventually it needs to come out, but the problem is is that 3 of the 8 screws are stripped, so i need a way to take it out without damaging it, o and the surround is made of metal not rubber. Any ideas?
September 17, 200818 yr Ok, when I bought my speaker from my friend he gave it to me in this small, crappy made sealed enclosure and i need to take the apeaker out, not necessarily right away, but eventually it needs to come out, but the problem is is that 3 of the 8 screws are stripped, so i need a way to take it out without damaging it, o and the surround is made of metal not rubber. Any ideas? take a flat head screw driver... put it under the lip of the basket... while you unscrew it with the phillips head create up preasure with the flat head.... see what im saying.
September 17, 200818 yr yeah if the screws are stripped it means they aren't holding on to much. Just have to pry them out like bigjon said.
September 18, 200818 yr Author no the actual screw isnt stripped its the head of the screw that is completely stripped out
September 18, 200818 yr if you can get to them wit a dremel you can cut slots in them.or you can go to a sears store in the craftsman tools section, and look for these bits that go in a drill they are made for taking screws out with stripped out heads.i want to say they are called screw outs not positive on that one.
September 18, 200818 yr Author old school audiobahn immortal 18, just keepin it till i can afford my nightshades =-), or an x-con Edited September 18, 200818 yr by BristaBrock
September 18, 200818 yr this http://www.sears.com/shc/s/p_10153_12605_00952154000Por this http://www.amazon.com/EXTRACTOR-SCREW-SPIR...C/dp/B00008KISI
