Posted September 21, 200817 yr I KNOW THIS DOESNT HAVE ANYTHING TO DO WITH THIS FORUM BUT PLEASE HERE ME OUT AND ANSWER THIS!!!I'm holding off on the 4 BTL's just for now until I get my money right but for now I want to know if this is a good setup?I plan on buying 5 of these (To Save Space)http://www.sonicelectronix.com/item_3835_Kicker+05C84.htmlThis amp for subshttp://www.sonicelectronix.com/item_9551_H...+TXi+1008D.htmlThe box is going to be custom made (To fit the trunk) (Ported) maybe tuned to 27 Hz.,is 27 Hz. loud or should I tune lower? And its going in a 2004 Chevy Aveo. Im going to parallel wire the 4 ohm subs to 2 ohms. For a educated guess do you think I'll be hitting @ leats 140db? If not how much to be specific? Will it be hella loud even though their 8 inch woofers because of alot of cone area & bass? I said that because 5 8 inch woofers is like 3 15's,or 4 12's help me out if im wrong:(P.S:How should I wire all this? and if you need more info. to get a better answer please feel free to hit me up! [email protected] and do you think 5 8 inch subs can fit in a 2004 chevy aveo? 8 inch subs are really small and if this helps (I HAVE THE SEDAN AVEO NOT THE HATCHBACK ONE)thanks again I surely appreciate your help!!!!
September 21, 200817 yr If you knew this didn't belong in this forum why did you post it here?? There are other forums on SSA dedicated to stuff like this
September 21, 200817 yr Author I know I couldnt find it kinda new to this but could you please help me out
September 21, 200817 yr there's no way to answer almost any of your questions.I personally think 27hz is too low for you, a higher tuning will be louder.dunno if it'll hit 140s, nobody else here knows either, only one way to know....the one question i can answer is that i wouldn't buy that stuff, and i sure as hell wouldn't buy it if i planned on getting something better later, you'll never get your money back out of that equipment, save it and get what you actually want.
September 21, 200817 yr Author there's no way to answer almost any of your questions.I personally think 27hz is too low for you, a higher tuning will be louder.dunno if it'll hit 140s, nobody else here knows either, only one way to know....the one question i can answer is that i wouldn't buy that stuff, and i sure as hell wouldn't buy it if i planned on getting something better later, you'll never get your money back out of that equipment, save it and get what you actually want.Thanks I appreciate you help ''Vladd'' Oh yeah before you go can you tell me which forum to post this to and how to get to it so I can get answers please Edited September 21, 200817 yr by Randy.D
September 21, 200817 yr a mod will move it soon, don't bother posting a new topic, people will answer as they see it, keep in mind this is sunday.
September 21, 200817 yr Author a mod will move it soon, don't bother posting a new topic, people will answer as they see it, keep in mind this is sunday.Thanks ''Vladd'' you've really been helpul!! I'll leave you alone now. I really appreciate it.
September 22, 200817 yr 2 8s is a little less cone area than 1 12". So no where near what you are thinking... 4 8s is right at 1 15". So yes, it should be fairly loud... but I highly doubt 140 with a 27 Hz tuning. Tune higher with the 8s for more output and probably happier drivers overall mechanically.Thanks,Scott
