Posted September 25, 200818 yr I have finished the boxx for the 2x 15" WMD^2 subs w/ carbon fiber cones.wanted to have a boxx for MUSIC, not SPLthe external dimentions are H- 18"W- 41.5"D- 35.5"Port was rear fireing 2x pieces 16.5" x 23.75"overallH- 16.5"W- 5"Lv- 23.75"I was shooting for 25Hz port Freq: got D@mmm Close went for a drive and it really POUNDS on the lower notes and has SMOOTH Transition between higher notes... the subs are loacted on the rear of the boxx facing Up ^^ neer the back window port fires to the rear door seperating the subs and BRACING the boxx Pics / a lil late but better than never Strapped @ 1ohm / 0.5ohm per amp DAILY
September 25, 200817 yr 25hz is low, next time try 28 or even 30hz. Going much lower in a car doesn't actually help. Nice to see you trying something new though.
September 25, 200817 yr Author 25hz is low, next time try 28 or even 30hz. Going much lower in a car doesn't actually help. Nice to see you trying something new though.i tuned it too the Fs of the cone i gotta say it is nice being able to hear the notes that fade out on a box tunned higher / this thing has the Flattest responce iv seen on a plot/cruve.it does play clean and clear @ lower freq, i had ordered those sub built to take the power i was going to use and had 2 spiders & additional pole venting too keep the coils cooler i have been pounding them in an 11cf enclosure for 2 weeks now and i havent smelled the Glue burn off yet they havent gotten warm enuff with 2x 3000d amps STRAPPED playing in a box ported @ 25Hz !!!!!!!!!!!!!!!!AMAZING i know its not the tipical SQ box, and thank you for the kind input... do you think i should round off the corners on the Port openning ?@ lower volumes i can hear faint port turbulance...
September 25, 200817 yr Rounding the corners of the port could help with the turbulence.. making the port slightly bigger would also help though.
September 25, 200817 yr Rounding the corners of the port could help with the turbulence.. making the port slightly bigger would also help though.I was thinking the same about rounding off those edges.
September 26, 200817 yr Author Glad to see you doing a box like this. Thank you i did round off the port corners & got the boxx finnished / carpetted etc etc etc Looks Freeking Sweeeeeeeet will post pics later
September 26, 200817 yr now that you have stepped into the world of musical enclosures finally (welcome BTW) i'm anxious to see how long it is b4 that 12" T-line gets built lol Edited September 26, 200817 yr by kandiman
September 26, 200817 yr Author I am going too build A T-line or a Folded Horn for the 12" but as of this comming Monday i have a Custom built 18" Beast arriving UPS going to build an X1 enclosure see>>> http://www.speakerplans.com/index.php?id=x1
September 30, 200817 yr What's the giant line of glue curved across the top of the box?Not bad though. Last box I built was around 32hz and I thought it was darn near perfect.
September 30, 200817 yr Author What's the giant line of glue curved across the top of the box?Not bad though. Last box I built was around 32hz and I thought it was darn near perfect.the gule was from previous attempt to build a box i saw in a supermodd van / i had did a ruff estimate and cut the dimentions in half thinking it would slamm @ss in the SUV and it did above 90Hz, but not below 80Hz this was the boxx that Floopped so i took it appart and rebuilt it into the Bigg 25Hz Beast
September 30, 200817 yr with that first box try making your sealed chamber a little bigger and cut your port area by half.
October 1, 200817 yr looks like that box that flopped was just a 4th order bandpass that was tuned too high....try tuning to your peak frequency Edited October 1, 200817 yr by aznboi3644
October 2, 200817 yr Author SADD but True it was a 4th order banpass that i tried winnging off the top of my head and it flopped Baddddddddddddddd
October 4, 200817 yr Tuning to driver Fs usually isn't the right answer. Most subs want a tuning a bit higher than that, some lower, almost none right at. Without T/S parameters you're just guessing at volume and tuning. Not the best way to get nice response from a sub. At least you're giving it a shot. :thumbsup:
October 6, 200817 yr Author Tuning to driver Fs usually isn't the right answer. Most subs want a tuning a bit higher than that, some lower, almost none right at. Without T/S parameters you're just guessing at volume and tuning. Not the best way to get nice response from a sub. At least you're giving it a shot. :thumbsup:i am going to have it metered and find out what it wound up being / i had planned on the ports being 27" / but with the wood i had it wound up being 24.75" so i think its tuned to about 28Hz i just wanted to try something different closer to SQ / take a walk on the SQ side of life i know its not an 8" sub but it was as close as i could get with the equipment i had on hand,thats why i contacted PAP and had them build a set of Musical subs that could take the power from Both the Sundown Audio 3000d amps i have a 12" SS SPL-X quad coil but the tollerance on the coil gap is tight like the RE MT - not ment for Music /
