Posted September 28, 200816 yr I am needing to get the specs on th is sub.Unfortunately, I do not have much information about it. I know it is several years old and never been used. here are the pics i have of it. It also has a sticker on the side of it that says XS01048. I cannot find this particular sub on their list of subs on their website. I posted something similar to this a few years back and got nothing but off topic responses. I would really like to find out any info on this sub you guys might know. I have emailed power bass but have not gotten a response yet. Thanks for your time.
September 30, 200816 yr POWERBASS PBX EXTREME XS-10Dv.2 SPECS: * DUAL 2 Ohm Voice Coil * Rubber Surround * Rugged Competition Die Cast Aluminum Alloy Basket Frame with Aerovents * Spruce Pulp Paper Cone * Chrome CNC Machined One Piece Bumper Back Plate * Extended Pole Piece * High Temp Black Anodized Multi-Layered Dual Aluminum Voice Coil * Double Stack Performance Magnet * Recommended for Ported Enclosures or Sealed Enclosure * Resin Impregnated Dual Poly Cotton Spider With High Current Woven Tinsel Leads * Freg. Response: 20 - 500 Hz * SPL Sens 1w/1m (dB) : 84.4 * SPL (2.83V/1m: 92.58 * Vas (Liters): 21.16 * Mounting Depth: 6.3"800 watts RMShttp://cgi.ebay.com/POWERBASS-PBX-XTREME-1...9QQcmdZViewItemXS15Dv2Specs:FS: 29Hz, Qms: 3.7, Qes: .38, Qts: .35, Vas: 89.6, Nominal Imp.: 2ohm + 2ohm, SPL 1w/1m: 91.5dB, X-max (one way): 13mm, Pe: 1000w rms / 2000w peak, Freq. Res. 20Hz-500Hz.Physical characteristics:Triple layer non-pressed Kevlar composite paper cone.Chrome plated single piece cnc machined back plate and extended pole piece3” black anodized high temp multilayered aluminum dual voice coilsHigh excursion dual oversized black conex linear spiders with woven tinsel leadsDie-cast aluminum twelve spoke basket with voice coil perimeter aeroventsUV treated rubber surround260oz. Double stacked magnetsAmp used: Cadence A7hc - 1200w rms @ 1ohmSQ / Box used: 3cu' tuned to 28HzI have been playing around with the sub for the two months now. At first I though the SQ was awful. After using different box designs, and it got broken in, my final conclusion is that for an SPL driver the SQ is not that bad. I have my amp X-over set to 250Hz. The higher tone bass is slightly distorted and laking, but if you want smooth lows it has plenty of room to spare. Another nice thing about this driver is that the extreme lows (>30Hz) can get really loud with out a lot of cone excursion. For this reason, the 1000w rms becomes more like 1500w rms. (Remember the box)SPL / Box used 4.5cu' tuned to 46HzI figured that there was no way that the PBX could duplicate what my 15" Brahma could do; I was wrong. In this box their numbers are identical. It seemed like there was no bottoming out when I would play low frequency bass songs. The Brahma would never be able to handle this for long play (aprox. 30min.) as the PBX did. I think that the power rating is greatly underrated and that it is a great compitition sub.Over all - 1 through 5SQ - 4SPL - 4.5http://www.caraudio.com/forum/showthread.php?t=59606 Edited September 30, 200816 yr by nick_19
September 30, 200816 yr I've still got a couple of those woofers lying around.. good little woofers... heck I use to burp one off 3k until I creased the cone..
