Posted January 10, 200521 yr Admin there is no information on their site,anyone know where I could find the info or who to email? I want to put these in a box up against the incomming 4 Funky Pup 8s
January 10, 200521 yr Second Gen Blue Thunders. Nice pick! If you have an exact model number, I can get you the info. If not, I'll have to give you the specs on every BT driver.
January 10, 200521 yr Author Admin Second Gen Blue Thunders. Nice pick! If you have an exact model number, I can get you the info. If not, I'll have to give you the specs on every BT driver.I dont have an exact model number sowwie, me =
January 10, 200521 yr Author Admin Nothing anywhere? Should start with BTL or BTW. all I know is that they are SVC 4s
January 10, 200521 yr Author Admin damn you got it on expert mode so about what do you think I should do box wise for ported with these suckers? :sterb104:
January 10, 200521 yr No idea, I didn't get that far. I'll plug it in though.Just the 2 of them? Power?
January 10, 200521 yr Author Admin No idea, I didn't get that far. I'll plug it in though.Just the 2 of them? Power?the power will be low, nothing more than 500 watts, I would dig through my pile of RF amps sitting around here
January 10, 200521 yr Try this.That's as big as I can get it. Won't let me add any attachments so. . .
January 11, 200521 yr 1.25 @30.55They won't handle 500 in that enclosure though. At least as far as the graph said. 300 was the max before cone displacement got out of control. Are you burping them? I know nothing about SPL, so that's not what I was looking for. If you want a higher tune, let me know, I'll throw that in, or more port area.
January 11, 200521 yr Author Admin 1.25 @30.55They won't handle 500 in that enclosure though. At least as far as the graph said. 300 was the max before cone displacement got out of control. Are you burping them? I know nothing about SPL, so that's not what I was looking for. If you want a higher tune, let me know, I'll throw that in, or more port area.oh these are not for competition don't worry, I could put my RF 250a2 on them and give them about 160 (approx) each @ 4and thats 1.25 per right? do you know the length of the port? I would be doing a slot port for these like I did for the H2
January 11, 200521 yr Author Admin 12.25sq." @ 27.39"LThe 1.25 is the NET for BOTH drivers and port.sweet now I just need to figure a cut sheet and I am off to Home depot
January 11, 200521 yr 12.25sq." @ 27.39"LThe 1.25 is the NET for BOTH drivers and port.sweet now I just need to figure a cut sheet and I am off to Home depot Give me your maximum dimensions and I can plug that in there too. I can fit something in.
January 11, 200521 yr she needs to be no large then, ummmmm38d,28,36 about 5'6"..oh hell...wrong thread my bad... wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
January 11, 200521 yr Author Admin 12.25sq." @ 27.39"LThe 1.25 is the NET for BOTH drivers and port.sweet now I just need to figure a cut sheet and I am off to Home depot Give me your maximum dimensions and I can plug that in there too. I can fit something in.this will be tested in my explorer so there is no limit essentially for 2 tens
January 11, 200521 yr 12.25sq." @ 27.39"LThe 1.25 is the NET for BOTH drivers and port.sweet now I just need to figure a cut sheet and I am off to Home depot Give me your maximum dimensions and I can plug that in there too. I can fit something in.this will be tested in my explorer so there is no limit essentially for 2 tensThose were 10s? I thought they were 8s. NM then, I have the wrong drivers. Back to work I go. Dammit!
