Posted September 30, 200818 yr I was wanting to get 2 15" Chaos subs but didnt know how many watts I should run to each. Can you help?
September 30, 200818 yr I have a 12" chaos with a sundown sae 1000d on it and it is just bad ass...... hahahahhahaAloha Edited September 30, 200818 yr by yama168
October 3, 200818 yr Author If you get 2 Chaos subs, an SAZ-1500d is perfect.What about a Clarion 1551? are those any good?
October 17, 200818 yr If you get 2 Chaos subs, an SAZ-1500d is perfect.What about a Clarion 1551? are those any good?An SAZ1500D would be much better.
October 27, 200818 yr sO 4 ON A 40.1 OR 3000d would work huh maybe I can do a little bass race setup next year.Also the website says RMS is 1250 not 800# Tough daily driving sub that has excellent SQ and output ability.# 12", 15" and 18" Dual 2 Ohm models.# Triple stack FEA optimized motor# 3" 4 layer aluminum coil# Triple layer reinforced collar# Quad progressive spiders# Ultra rigid reinforced cone body# Hybrid foam surround# Cast Alluminum basket# Wrap round rubber gasket# Silver 8AWG Push terminals# 1250W RMS Edited October 27, 200818 yr by Silent
October 27, 200818 yr sO 4 ON A 40.1 OR 3000d would work huh maybe I can do a little bass race setup next year.Also the website says RMS is 1250 not 800# Tough daily driving sub that has excellent SQ and output ability.# 12", 15" and 18" Dual 2 Ohm models.# Triple stack FEA optimized motor# 3" 4 layer aluminum coil# Triple layer reinforced collar# Quad progressive spiders# Ultra rigid reinforced cone body# Hybrid foam surround# Cast Alluminum basket# Wrap round rubber gasket# Silver 8AWG Push terminals# 1250W RMSthese specs are for the havoc not the chaos hes looking for chaos...Aloha
October 28, 200818 yr Dooh Damn your right dont know where I was reading Edited October 28, 200818 yr by Silent
October 28, 200817 yr you could also try 2 sae1000d's as yama 168 says he gets good results from that combination also. Edited October 28, 200817 yr by mikett
October 28, 200817 yr yes i loved that combo but didnt have the room needed for the 2 sae1000d's :)Aloha
