Posted September 30, 200816 yr Just wondering which would be the better sub..They are both priced about the same..And the handling is about the same also..
September 30, 200816 yr Just wondering which would be the better sub..They are both priced about the same..And the handling is about the same also..Are you more concerned with output or accuracy?
October 1, 200816 yr Author Actually if you guys had the choice between those two subs whgich wud you go?I hear that the Mach 5 has SQ and the SSD had SPL and SQ..Juss not sure on both subs..
October 1, 200816 yr Why would you care what we'd choose? I guarantee that your listening preferences and mine aren't anywhere at all alike.The real question is what are your expectations? Without those no one can recommend a sub for you.
