Posted October 2, 200816 yr alright so.. i've been saving up money for almost half a year now and i really wanna get a good set for my carbut the thing is, i have no idea what parts i should buy that best suites my cari drive a 2004 acura tsxi've been hearing from my friends that i should go w/ sound spintersso, i ambut the thing is.. what do i all need?i have no experience w/ subs or anything of that matterso far.. i'm considering getting two 10"s?good or bad choice?but i heard the 8"s were badass.and that's as far as i've thought ofno idea of what amp, or if my car can even use the subs w/out changing my deckanybody know any info that can help me out? Edited October 3, 200816 yr by miKooooo
October 3, 200816 yr definitely get a new deck, it will improve sound quality overallbigger subs are louder, hit lower notes, and require larger boxes (typically)first you need to figure out what you are looking for in a system (loudness, sound quality, etc), how much you are willing to spend, and how much of your trunk you are willing to give up. you could get a system with perfect SQ, or one that will blow out your windows. you can do subs that will fit under your seats, or take up your whole trunk.you could spend 500 dollars, or you could spend 5,000. and anything in betweenit all depends on what you want
October 3, 200816 yr Author alright, i narrowed my decision down a lil'so far, i'm just willing to spend about a grandmy tsx has a pretty big trunk, so i don't think space would be any problemthis dude did an estimate for the stuff that i need..he saidtwo 10" sound sprinters = 400box = 100wires = 50installation = 150amp = 200total = about 900'ish..?and that sounds just about rightshiit dude, my current deck..it's one of those built in onesso i'll probably have to get a new one..and i heard from some people that like..they're gonna have to tear out the whole front of the car. =/that's gonna be expensive right?but for sound quality, that's most importanti don't really care about loudnessand for sound spinters, i heard they got the best of both worldsthey're both loud, and kicks major ass in sound quality.
October 8, 200816 yr Author So.. I decided to do this..My cousin has two 12" pioneers in his basement, so i think I AM A use thoseuntil i can save up some more money to buy sound sound splinters. =Dbut.. I AM A' need an amp.he said that the subs are about 1000 watts each, so i'm going to need to buy an amp that supports 2000 watts..?so my next question is..where can a buy a good amp that will power these two 12" subs?i like.. want a really good one so that..when i work enough money for the sound splinters, i can just switch the pioneers for the sound splintersand hopefully get really good sound quality/power.. i thinkso.. i'm expecting to pay around.. 200-300 for a good ampanybody got any suggestions?
October 8, 200816 yr So.. I decided to do this..My cousin has two 12" pioneers in his basement, so i think I AM A use thoseuntil i can save up some more money to buy sound sound splinters. =Dbut.. I AM A' need an amp.he said that the subs are about 1000 watts each, so i'm going to need to buy an amp that supports 2000 watts..?so my next question is..where can a buy a good amp that will power these two 12" subs?i like.. want a really good one so that..when i work enough money for the sound splinters, i can just switch the pioneers for the sound splintersand hopefully get really good sound quality/power.. i thinkso.. i'm expecting to pay around.. 200-300 for a good ampanybody got any suggestions?dude you haven't mentioned anything about the upper frequencies. what are you going to do about highs? if you're into sq then you should start there first and then worry about the low end later. just my .2
October 8, 200816 yr What type of music do you listen to? And with those Pioneer's, you need to find out the watts RMS, and then match that with an amp. I would recommend a front stage upgrade before you touch substage.
