Posted October 3, 200817 yr I don't know if anybody can tell me if 2 18s will fit in my car, but i drive a Montero LS and my max dimensions are 23h x 35w x 40d. Will that be able to fit 2 18s ported or 2 15s ported
October 3, 200817 yr I don't know if anybody can tell me if 2 18s will fit in my car, but i drive a Montero LS and my max dimensions are 23h x 35w x 40d. Will that be able to fit 2 18s ported or 2 15s porteddo 2 15s. you got room for that.
October 9, 200817 yr you can fit 2 18's or 3 15's tuned LOW (28-33hz) probably 3 18's and 4 15's if you tune high (44hz & up)
October 9, 200817 yr you can fit 2 18's or 3 15's tuned LOW (28-33hz) prolly 3 18's and 4 15's if you tune high (44hz & up)3 18's im gonna say NO WAY
October 9, 200817 yr dont listen to jextel he dont know what the fuks going on....... 2 18s is cutting it. less than 5 cubes per if tuned with approx 15 sq inches of port per at say 30 ish.
October 9, 200817 yr X2, You can fit 18"s, but you will starve them of air. 2 15"s would be better suited for you.
October 9, 200817 yr thats 16cubes before displacement, u got more room than me, lol, prolly .5 for both subs so u have 15.5, then bracing.thats alot of dam room, then just get u some aero ports cuz a slot port, unless you put the subs on the top having 35 as a width ur not even gonna be able to fit them in the box, lolyea 2 18's ported go for it.
