Posted October 5, 200818 yr 2 15" L7 on a kicker 1500zx (spending under 1100)vs. 2 15" FI Q w/ JL audio 1000/1 (would be spending 1300)is it worth it to spend the extra $200?
October 5, 200818 yr I'd recommend having at least 1500 watts to run two Fi Q's... 2000 preferably.IMO, they can work fine with less power than that
October 5, 200818 yr Author now ive got my mind on the FI Q's but now 12" or 15" i want it to be loud
October 5, 200818 yr now ive got my mind on the FI Q's but now 12" or 15" i want it to be loudThen in that case...ignore what I said.
October 5, 200818 yr now ive got my mind on the FI Q's but now 12" or 15" i want it to be loudhow much are you willing to spend on an amp? because i have a good one in mind for ya;) Edited October 5, 200818 yr by RobClay
October 5, 200818 yr Author i have a 1500zx in my room but im looking to get the jl audio 1000 1 to power 2 FI Q
October 5, 200818 yr I dunno..Im new to car Audio but Fi Q's fer sure..And if your going to buy a JL Audio 1000/1Fer how much your spending on that you shud just buy a Rockford Fosgate or a Sundown amp..
October 5, 200818 yr i have a 1500zx in my room but im looking to get the jl audio 1000 1 to power 2 FI QIf you already have that amp, I'd go ahead and use it.Fer how much your spending on that you shud just buy a Rockford Fosgate or a Sundown amp..The JL does have some benefits over RF or Sundown, but I'm not sure it's really going to matter for what he's doing
October 5, 200818 yr Author will the 1500zx power 2 12" FI Q with some loudness? cause the kicker amp isnt stable at 1 ohms
October 5, 200818 yr i know an amp that would be perfect for them q's and its stable at 1ohm:) haha and ur budget would be a lil over 900 with the 2 15's and "this amp" Edited October 5, 200818 yr by RobClay
October 5, 200818 yr will the 1500zx power 2 12" FI Q with some loudness? cause the kicker amp isnt stable at 1 ohmsHave you already ordered the Q's or something? Because unless you have, I don't see why that would be a problem...
October 5, 200818 yr well wat is it and how much is it?its an audioque2200D its stable at 1 ohm price is 389.99 free shipping my friend has this amp running 2 rockford t1 15's
October 5, 200818 yr Start with your needs and desires and not with equipment choices.this man speaks nothing but the truth
October 5, 200818 yr Author i basically want something that will be loud and can be very noticeable and reliable...i have the 1500zx but i can return it but would the 1500zx be able to make 2 15" or 2 12" FI Q bump? because i was told that the kicker amps werent stable at 1 ohm
October 5, 200818 yr i basically want something that will be loud and can be very noticeable and reliable...i have the 1500zx but i can return it but would the 1500zx be able to make 2 15" or 2 12" FI Q bump? because i was told that the kicker amps werent stable at 1 ohmit will be loud. but you just cant wire the subs to a 1 ohm load on the amp if you keep the kicker1500, i would return it and buy that aq2200 and then it would be alot louder, perfect match for the q's at 1 ohm they will be seeking around 1100 watts to each sub
October 5, 200818 yr just order your subs in dual 2 ohm and wire in series and then parallel then you will have a 2 ohm load to the amp
