  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
freakin psycho kid
he must have been bored
Nick, i have a 4ch and a H/U ;)
both start with B
heheheheh
if only i had something to trade for your uber :(
Nick you there?
Nick can you elaborate on the Orion and Higher voltage for me,  IHoP may be better so not to jack this thread
The signal input stage, does not like more then 5-5.5 volts.
I can explain it... i ran across it twice in my truck... but lemme find a recent link for yah too.
I may be introuble then, or I will have to reset my gains on other amp so that the 8v is running more at 4v or 5v.
Could you explain to me the signs of what happen so that I dont over drive the amp with the signal?
oooh good point.
easy on the volume for sure.
I can tell you that:
1200D
2500D
8002
In my truck (always a good 14.2v+ supply) with the 860mp (6.5v outputs)... all three of those amps have the sensitivity at nill. I'll run upto volume 35/40 for a burp (with all rcas unplugged except the sub amp)... but only 32/40 for music. Even that level is rare.
Currently I am running
75/80 with the memphis at no gain(all the way down) the SPL@ 1/4 and when the HCCA is hooked up at zero also.
I have a feeling that the 600D will either A) be the same or B) not like it and make me have to re set the level and gains.
signs? distorion - no matter the volume / clicking (as mentioned at TP) / signal fading / "delayed" output (seems like the music is a beat behind.
Again, because the rca line voltage wont be at 8v all the time... you should be alright. You're no n00b; but set the gain accordingly, leave a lil headroom if you can.
The orion's (of today) are 'efficient' amps as it were. They do not need very much input to broach full power.
I think that I leave the volume the same and just turn the sub level down accordingly to about half of what I have it at now. Currently at 16/16 so 5 or 6 to set it with a max of 8, that should be OK.
yea, you'll prolly be fine.
i ran both 2500's on the sx's for music for a short time... pushed them pretty loud and really had no problems.
hell, i clipped the chit out of the deck (40/40) when i had a 1200 on a DD.. thats when it was noticalbe a few times, but barely.
:D
really, that sounds good.
Thanks for the help mang, the amp is sitting in my room and going to be hoked up tonight. Still no bites on the SPL
no problem... thats what we're here for, right? LoL
and good luck on the amp.
You list it at CarSound?
Currently at
CA.com
CAW.com
SSA.com
Elite.com
and replied to a SD WTB post
try carsound. lots of grown up buyers there.
pio's will clip at full volume, did that on my 4600.
man dd it ever sound bad !
( no speakers were harmed )
This is more of an entry level amp, but Ill try it out.
