  • Replies 317.8k
  • Views 13.7m
  • j-roadtatts
    j-roadtatts
sounds kinda dangerous too.
Fuuuuuuuuuuuuuuuuuuuuuuck soldering.
SMD or regular?
You don't know the meaning of self-inflicted torture until you try to solder surface mount components...
Have you poked around with a DMM?
or is it a cold solder joint...
What were you using to cut it?
I've never had a problem with cutting PVC...
PVC pipe saw
I've used my scroll saw, with a very fine blade, to handle most PVC work that I've needed...for bigger stuff, I've used a Sawzall for the rough cuts, and sanded down closer if I needed it exact.
Wish i had cool tools. It was either the pvc pipe saw or the circular saw...
What blades do you have for the circ? That might not have been a bad choice, if you had a fine-toothed blade for it (not a ripping blade).
Ya i was just joking cause the blade on it definitely wouldn't work.
