  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
PCO: political correctness overkill.
People keep b1tching saying that big trees on display should be called "holiday trees" instead of christmas trees. I mean seriously, did people run out of chit to whine about?
Even when Bush sent out the presidential holiday greeting card and wished people a "happy holiday" instead of a "merry christmas", all the religious people started whining.
yea they run out of chit, and then move on to the next topic. Christmas was an easy one, i'm curious as to what they'll female dog about next.
people are so pucking retarded
puck puck puck
puck puck puck
puck puck puck
isn't symmetry beautiful?
craftsman!! i love mine although i don't have the model number on me off hand. All the usual stuffs plus a temp gauge/probe and a thing that will measure frequency, although only to like 10hz accuracy...is that right??/ 30hz reads as .3 on the meter as would 32 or 30 anything, hey its 7am
its 7am, i have a habit of ranting when i haven't slept. I think i figured out how i'm going to fit 15s in the stratus and still have trunk space though
stratus has a total mounting height of about 16-17" but i only want to use 14 because of the weird lip on it, hard to explain but doesn't matter. My width is 36 maybe a couple inches more at best. The box can extend back as much as 36" but that won't leave me any trunk space at all.
What i'm thinking is a box that's 14h X 36w X 26L which is about 7.58 cubes outside dim.
This design only leaves me with about 10" in the rear though, not exactly a trunk :-P.
Next i can do the typical sealing the subs off from the cabin, take a dremel and saw off the edges around the lip to the trunk giving me the clearance needed. Then i keep the subs firing forward and my height can go up to...17 at least. 17h X 36w X 20l (7.08 cubes) gives me about 16" in the trunk area...better but still not desireable
So at last, i do fiberglass and MDF like i talked about before, i can squeeze out way more than the typical rectangle box cause of the wheel wells. I do two separate enclosures cut right down their symmetrical center and that allows me to remove the enclosures if they're short enough, if not they should be able to slide around till i can get them out through the front.
Yes i think that might be a plan....
