36-37hz
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
that'll sorta explain it... your box should be peaking around 40.
i though boxes typically peaked 10 cycles or so higher then tuning??
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
depends on the wofer. with that kind of susp i dont think peak will climb toooo much in a 2.5 box.
  • Replies 317.8k
  • Views 12.9m
  • j-roadtatts
    j-roadtatts
mass fighting compliance...
36-37hz
makes since...
also, i've though about adding another one ot the same box...should drop volume to about 2 cubes even and raise tuning to about 40 hz..and have them share the 2.5k+ at .5ohm
whatcah think???
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
right at tuning / peak, you'll have the cone fighting the susp & box susp very badly. i dont know the X very well personally, but from the specs IIRC... its a heavy cone vs. a heavy spider(s). and in a small - mid box it can be tough.
36-37hz
makes since...
whatcah think???
good for alot of power.
kicker recommended 2.25ft^3, 42in^2 of port tuned to 44hz IIRC for a tuner box..i dropped the tuning..
so..by raising the tuning and adding cone area..i shouldn't lose too much on the low side, but gain alot on the high side...correct??
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
alrighty...
i'm out as well...
again nick, i apologize for bieng rude earlier....
thanks for ur input tonite!
first post of the day in the IHoP..
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee:slayer:
i> j0o ppls..
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
i bet 7.5k gets here quickly..
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
T.O.P. beyotchssssssssssss
first of the day as well...
i>j0o (just in case u forgot in three posts..)
i owe
i owe
so off to work i go
because because because because becauuuuuuuuuuuuuse
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
:banhim: :dancingsmilie: :stupid::lame::foshizzle:
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
wooowhoooo 7040
ok..i'm done...lol
i hand it off to nick, justin and supa...
have a good one ppl's..
Kent, i have school. So no whoring before hours.
**gone**
i'm off of work today... which means i wont be on the PC much. working round the house <yay>
