oh, i also have mids on the way (poly mids, AA) i'm going to try them and then probably get some vifas or seas and compare
  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
try arguing that you shouldn't put platinum in your car cause it runs too hot (turbo) or that they are giving you the wrong spark plug,  you need a (colder/hotter) one
That will get them too.
I go up to the counter and ask for 8 Autolite 764s. They proceed to ask what vehicle. I tell them again, I need 8 Autolite 764s, they again reply that they need the vehicle. I say, give me plugs, they say need vehicle info. I ask why, they say warranty. . . WTF? Warranty on a damn spark plug? Give them vehicle, they say, no, I need platinum. I ask why, they say because that's what their computer lists. I ask to see the screen, scroll down, and bingo. . . Autolite 764s @ $1.09/pc. Give them to me. They try to tell me I NEED platinum, I tell them to explain to me WHY I need platinum. They go on some stupid autostore BS knowledge. I school them and get my 764s.
I feel sorry for some of the people who actually take that job hoping to learn some automotive knowledge.
i got spark plugs tonight :)
that makes me happy :)
one less thing to get to fix my car :)
8, technically :)
now im just waiting on headers and cats which should come next week :)
You wanna have a good time when you go get plugs?? When they tell you your car requires platinum plugs, ask them why they make copper plugs for them then? Then proceed to tell them that platinum plugs offer zero advantage unless you plan on not changing your plugs every year. They'll have a fit.
i already knew the part number of what i needed so it was really no hassle at all
with non-platinum plugs, it's really recomended to change them once a year?
I don't change plugs every year...partly because it's an exercise in frustration just trying to get to them. Have to change them from *inside* the cab...
Only van I ever liked to work on was my mother's old Aerostar. The 4.0 had great access in that thing with the low floor. Typical full size vans are teh suxor!
8, technically :)
Yes. Platinum is acutally a very poor conductor and there are far better performance characteristics from a standard copper plug. The ONLY advantage to platinum is durability. It allows for a much longer lifespan due to better corrosion resistance and better durability with long term heat.
Actually, this is not commonly known, but you should really replace your plug wires everytime you change plugs. Plug wires will start to deteriorate around 10,000 miles or less.
That is something I do...once again, because it's such a PITA to get everything exposed, might as well do as much as you can while you're there.
But it's probably been 20k since I've touched either the plugs or the wires...might have to change the distributor cap the next time I do it as that hasn't been touched in a while too.
It's sort of raining here...
Might as well get it done with now, if it rains tomorrow I'll be pissed considering the weather here this afternoon.
I see Her N00bness reading... :D
8, technically :)
good info Ryan, thanks
so you recomend plugs and wires every year?
8, technically :)
I do it for all my own vehicles, but I'm a little anal on maintenance. I do a tuneup once a year, and that's all tuneup related, so voila. Plugs, wires, cap and rotor if applicable, fuel filter, air filter, oil change, tranny fluid change, gear lube change, coolant change, etc.
8, technically :)
the opti on LT1s is a pain in the ass, you have to take the water pump off to get to it
i'll try not to let this set of plugs/wires go too long though
and i just read that thread, and wow.....
...quite odd
You'd think he'd know how to bring it up in conversation, maybe take her out to a fancy restaurant...after all, being his GIRLFRIEND and all. He'd already have done most of the work. Unless she's just using him for cock, which seems highly probable...
...quite odd
if theyre a couple, then i would think it's already pretty much implied that they'd go together
i'd just be like, "pick you up at 7"
