lol at elias....i didn't think my 3434 was all that hard to figure out.
steve, you will have package on the way tomorrow!!
justin....i can see the vids just fine.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
This one is a bit tricky. Defnietly not user friendly in pro mode.
  • Replies 317.8k
  • Views 11.9m
  • j-roadtatts
    j-roadtatts
I love my eclipse 8053. Only a few decks Id give it up for. Pro mode wasnt hard for me to figure out. I did read the manual first however ;)
You guys think 1 4" aero is enough for my entasi ?
Or will i get some port noise
If i had the manual i wouldve read it :P
Thats what happens when you are given stuff
i saw the first one, 2nd one is trying to connect now
What size enclosure and power? Lower power, you'll be fine.
I was thinking 2ft^3 gross and prob 6-700W.
You'll need more vent area.
bah....one twelve, one 4" aeroport. unless he goes mucho power, i'd bet he'll be fine. unless he listens to the port right next to his head.....
yada,yada,yada
crap crap crap
I guess i'll have to do dual 3's then
I was going to get the 4" for free
T.O.P.
yep, that spells top!
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
yada,yada,yada
The amp is rated 1500@1 ohm and its a dual 2 ;)
Its going in the burb so i'll hear the port noise if there is any
i'd still wager that if you run the 6-700wrms port noise will be minimal, if at all existant with the 4" aero (especially if it's f;ared on both ends). run full power and then i'd suggest a second 4".
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
The problem with the port is that its already cut and glued.
So if i get both of them the tuning will be like 40hz.
