  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
still have to fold the port vinyl down, and cut the amp racks shorter.....again
See what I mean about the corners. I really fudgeed those up right at the front, the rest looks fine. Im pretty mad at how that turned out.
Edited by Devillain
Gonna be honest with you Corey, the vinyl in the corners does need work.
Just a thought: how about vinyl just in the front and carpet on the rest of the box? I did it on my old box, looks pretty slick IMO.
The vinyl alone would still look great, just gotta work on those corners. The amprack looks great, cant even tell theyre even mounted on anything.
Indeed it did look sick
I kinda figured I would catch it for the corners. As soon as I cut the first one I was like chit. then the second one I fudgeed up the same way. Im thinking of a way to fix it or hide it, but not coming up with anything. Thanks for the constructive criticsm.
what are you using to stick the vinyl to the box?
its pucking bullchit. I suck. I need more practice. Give me the techniques!!!!!
get a heat gun, and use it on the bask side
it does wonders ;)
I couldnt find my heat gun before I left FL. And can you believe that there isnt a blow dryer in this house up here? Crazy. hahaha Thanks for the pointers.
Edited by Devillain
i used contact cement on mine, but that was with carpet, the spray adhesive i used with the vinyl on my back deck is still having trouble sticking
PE banana plugs were rather expensive when my daddy bought em :(
I just bought three pairs from PE for $3.25 each...the compression fit ones. Really easy and very secure when tightened.
ello Jim, Elias, Lova.
it does wonders ;)
thats weak
Heat guns get way hotter than hair dryers though
And 3M super 90 > all
I bought a buttload of groceries for < 10 dollars
I'm so fudgein proud
i'm so learning to be a girl.
And it's only taken 21 years...
ahh gee
how long did it take you Jim?
