  • Replies 317.8k
  • Views 13.7m
  • j-roadtatts
    j-roadtatts
I take no credit for it either, Nick M. showed it to me...
We have a TON of those cruising around here too. Always cracks me up, especially when I pull up next to them and give them a look and they think they can run with me. Really not fair to the Honda's when it is almost always when we are already doing 65 on the highway, which from that point on my car really pulls. I love ripping them up though. Reminds me of 16 candles. When the group of asians are racing Lain and he wins, the girls with them start hitting them and such. The looks the passengers give the driver when I tear them up is similar.
Question...
What is the difference between the european and american FM?
I have the oppertunity for the japaneese pioneer p90 combo...its black ;)
But they told me that the radio wont work...any way to fix it so that it does work?
So it's a Japanese market radio?
The European and Japanese FM allocations are different...
Both use 100KHz channel spacing instead of the 200KHz we use here in the States, but the Japanese use 76-90MHz instead of the 88-108MHz used elsewhere.
And Europeans use 50 millisecond pre-emphasis on the MPX stereo signal instead of the 75-ms here, though I think it should be reverse compatible on the receiver side. Not sure what the Japanese do with that.
If it's a true JDM part with only the 76-90MHz range, they do make downconverters to take the 88-108MHz signals and bring them down to a frequency the radio will take.
However, you've still got 6MHz less of coverage, so if you happen to live in an area with some strong local stations, you're going to get some nasty interference (called "intermodulation distortion") that's going to result from the radio trying to cram everything into a narrower spectrum...or I've seen some that just drop 6MHz off the top end, so you've got 88-102MHz.
The black one is soooooo uber hot. Fudge the radio, get it anyways Justin. I don't think I've listened to the radio for more than 5 minutes in the last year or so.
Thanks for the info Jim. Someone in CA.com pointed me out a converter, but I listen to a wide range of stations...
93.3
92.5
100.3
102.1
106.3
105.3
Those are on my main set of stations, the other three sets arent as important.
I really could get by with just 102.1 and 105.3, but I would like the others too...
Dennis, I know the black is fvcking sweet... *cry*
I just wish the radio was different. I am bidding on the US version now.
Radio= a way for people with stock to have music.
J
Only radio that's worth a crap to listen to anymore is shortwave, and that's all out of the country anyway.
Very few domestic stations are worthwhile...unless you find a pirate or some rare Class D low power station that's still in operation.
I hate radio...........usually staticy, and not good music.
J
back 2 work..........have fun dudes and dudettes
J
Static just means your antenna isn't big enough :wacky:
The internet is really what's doing in broadcast radio, even on an amateur level...no real point in investing $2000 to set up even a 100-watt station that might get you 40 or 50 miles under ideal conditions when you can get a broadband connection and stream your music worldwide.
I lost the p9...by $20
dude bid at 2 sec left...
I know where there's one for sale for $850'ish...
