  • Replies 317.8k
  • Views 13.7m
  • j-roadtatts
    j-roadtatts
4.5 hours of sleep a day is killing me. softly.
checked out the fiero today, 8's should be doable,
CB, you said you were going to build a bench, to test amps. what resistors are you going to use ?
i asked a salesman about a 8ohm resitor, capable of handling 500w.
:hay: dennis
why only 4.5 hrs of sleep?
just bought a iva d300 :woot:
:hay:  dennis
Awesome!
I stay up till 3:30 because I'm a college student and that's just the way I function. Gotta wake up for school at 8.
i used to do that we would always watch bet uncut and then be aslepp in class
anyone know you could order random alpine parts from best buy.com
i asked a salesman about a 8ohm resitor, capable of handling 500w.  :ughdunno: why he gave me a weird look
butt load of 10w resistors for like $1 each cooled in distilled water. 50 of them could probably handle close to 1000w for short periods of time if they are cooled in water.
My guess is the temperature drift is going to net you 5% at best.
water is 5 times more heat conductive than air :) it also has a much higher specific heat.
But the problem is 5x is not enough.
Not much, CD Player. I wanna see pix of your 880 installed when it comes :)
Now I just have to pull out the heat gun and get rid of all the badging.
Cover looks good :)
I personally like the badging. I left mine on.
Whats the best way to remove badging anyways?? My friend wants the dodge and neon off the back of his car.
J
Cover looks good :)
Thanks. Mostly I have to get rid of the Leer/Radko and Z71 badges. While I am at it the LT badge will go too. I probably will remove the Silverado and Chevrolet once the gun gets in my hand.
And to answer the removal question, if you heat them up with a heat gun they usually peel right off. While the glue is warm, I just use my thumb to rub it off. Any residue is easily removed with a buffer if it doesn't come off.
However, if someone has an easier way now would be a great time to post it.
i cant find anywhere on the net on how Anodize aluminum...i wish 12 spoke baskets where steel so i could gun blue one.
just scrath it up...........it'll be ok
J
Thanks Scott!!!! Massive help........now where is that damn extension cord...?
