  • Replies 317.8k
  • Views 12.7m
  • j-roadtatts
    j-roadtatts
ALL DAY STAG????????
NICE
Pics of STFU
J
How do you attach the terminals to 1/0 power wire? I tried clamping it but it doesn't pass the pull test. My old wiring kit had some sort of glue in there and it was clamped down on the wire, so what do I do?
-John
If I'm wiring an ICON to 1ohm, I'd use this diagram right?
Would I just use a single strand of speaker wire to the box, go to both +,- and then split the speaker wire in half and take a black and blue strand to connect the 2 postives and 2 negatives on the speaker? I'm sure that's confusing, so is it ok to stuff 2 speaker wires into one terminal to make it a series connection?
or would I run 2 lengths of wire from the amp to the box and attach a + - to each voice coil? That would use all 4 wire connections on the amp, is that okay and would that make a 1ohm load?
-John
Edited by ILuvJDM
4 pieces of wire, jumper from - to - and jumper from + to + and then a jumper from - to amp - and + to amp +
computer
axles
water hoses
a/c lines
too much work, too little time
i really want some tubular control arms for the fiero too, but alas, nobody makes them
ok, so I'd cut the wrapping that's on the kicker wire (double twisted blue and black wire) and just use the individual wire to connect the sub in series, and then run 1 strand of wire like it comes and connect the master + and - on the sub to the + and - on the amp?
The push terminals on the ICON don't look big enough to fit 2 wires in there so is there another connection or do I just make it fit?
thanks for the quick reply, this install isn't going as planned :sigh:
-John
if you have a DVC2ohm and you want 1ohm you want to connect in parallel, not series.
and yes just cram the two wires in the terminal, unless you're using like 8ga speaker wire it should fit with a little work
i'm considering getting an 18" Q, 18 in the trunk=:-D
:orly3: :orly3: :orly3:
i just think it'd be fun, it would probably fit nicely too....let me do some quick calculations
hell i could fit 10cubes upfiring without a whole lot of work
sub up, port firing into the cabin...could be very fun
ok cool, thanks
-John
PS- any tips on the ring terminal question I posted earlier? I have no clue how to attach them without them slipping out eventually
Edited by ILuvJDM
strip off the right length and make sure the set screw is in tight. If the wire is seeing stress that's pulling it out then you need to fix your wiring.
-John
large phillips head screw driver + hammer
-John
I just hit it with a hammer, that did the job
thanks
-John
Secondskin has slow shipping. Ordered tuesday, arrives the next wednesday. I know its AZ to NY and the 4th of July was in the middle.... Damn 5 day shipping...
Not really too concerned. Having issues getting the space to fit the kinetik 2400 under the hood of my neon.
quick question, my SAE-1000D doesn't have red or black on the RCA inputs. Does it matter on a subwoofer amp or am I just blind?
-John
