Posted October 31, 200817 yr i'm having a problem positioning my tweeter since my car is equipped with pillar airbags. My only options are in the sail panel, kicks or the dash itself. With the sail panel, my only apprehension is that when i open the door, the tweeters might get wet when it rains ( by the way, comps are RE XXX6.5's so the tweeter is pretty open )If i put it in kicks, i might damage the tweeter since it has no grillsThe other option is the dash, but I'm wondering if this is advisable. I was thinking of putting it in a fiberglass pod enclosure, something like thisIs it generally better to make the tweeter face upward or towards me or towards my rearview mirror ? I'm using an Alpine 9887 so i might be able to play with the TA a little. If you have any pictures or references, i would be eternally grateful Thanks
October 31, 200817 yr Start playing with Velcro I've seen it done in pretty much every way you describe, and it's worked...so I'd start playing around with different positions.
October 31, 200817 yr Author I'm wondering if putting a grill on top of the tweeter would somehow decrease the sound quality coming from the tweeter ?
October 31, 200817 yr the short answer is.....nothe long answer is yes, but in the end you should easily be able to tune to compensate or it'll never be noticeable anyway.
November 1, 200817 yr Author I think im just going to put them on the dash, putting them on the sail panel and the tweeter would be insanely big and prone to raingonna try and experiment with some velcro, would anyone know where the passenger SRS bag comes out? heres a pic of my dash
November 2, 200817 yr I think im just going to put them on the dash, putting them on the sail panel and the tweeter would be insanely big and prone to raingonna try and experiment with some velcro, would anyone know where the passenger SRS bag comes out? heres a pic of my dashOwners Manual will tell you
November 2, 200817 yr by the way same position you're in with SRS bags in the A's. Let me know what you come up with.
November 3, 200817 yr Author i talked to the tech guys at the dealership and they advised me not to put the tweeters on the dash or the pillars. Ill just be going with the sail panel to be on the safe side.
November 3, 200817 yr The stealership will always tell you not to modify anything, but they are very short cited and usually idiotic when it comes to stuff like this. I'd ignore them completely unless they gave you very good reasons. If they just said I wouldn't, wtf do they know?
November 4, 200816 yr Author I think it was more to the tune of the airbags deploying and hitting the tweeters on the dash. I'll double check but ill definitely update you guys when the installs done!Thanks for the help guys!
