is there a fuse and if so where is it on a rockfordfosgate t3000bd
  • Replies 151
  • Views 11.4k
please respond i just purchaed one from some one and its not turning on and i think thta might be the problem ao before i get pissed and bummed can some one help me
i dont think it has external fuses. their in the inside and im not sure you can change them out
take a look at your fuse under your hood that connects your battery to your amp
well when you take the front plate off it to plug in the power and ground it looks like thre is a place for one but im not s ure
hm. upload a pic of what your talking about?
all my wiring is fine i just hooked another amp up to it and eveything works but the rockwofrd one still dosent
Edited by stuartgoodenough
ye. a fuse does go there.
Edited by RobClay
i bought it from a guy i now in my town and i paid 500 for it
a fuse does go there. and what im thinking you have to have the fuse to connect the 2 metal plate's to get power
Looks like a spot for a mini ANL fuse to me.
ye a mini anl. if i was in your situation i would try to find a mini anl 300amp fuse
but im really not to sure if they make a 300amp mini anl, i would try just to find the biggest one you can, like a 150amp
i think it only takes one. someone correct me if im wrong
i checked the manual online for it and it is a regular anl 300amp fuse. to see if it works you could connect the metal together with just about any fuse to see if it lights up. if it does get the right one.
