Posted November 7, 200818 yr I recently purchased the saz 1500D and last night as i was driving, my sub stopped playing and i heard a loud thud type sound right before it quit working. I checked the amp and the fuse were all blown. I replaced them with more and turned it back on. it took a second but my lights started to dim in my car then the fuses popped still. Everything being powered by the same power line is fine there is nothing wrong with anything else.What do you think the problem is. I believe its a factory problem
November 7, 200818 yr Author well i did replace the fuses and hooked it up into my friends vehicle to make sure i didnt have a short or something in my car but it did the same thing. when i power on the radio the lights dim or a second or two without playing anymusic and the replacement fuses blew. the amp didnt even display the blue led lights from the side when it normaly turns on.
November 7, 200818 yr Author sucks because i just go it a little over a week ago. does sundowns warranty cover it u think.
November 7, 200818 yr as long as you have youe sales receipt, send it in.... if the problem is caused by user then it will get fixed but a small fee will be charged. whats your charging system looks like? what kinda of load was presented? where was this amp mounted?
